Fuel gauge - sending unit problem
Old Apr 6, 2011 | 03:43 PM
raygk9's Avatar
raygk9
4th Gear
Default Fuel gauge - sending unit problem
I have a 1990 FLHS that has a non-functioning fuel gauge. I am not sure if it's the sending unit or the fuel gauge... is there any test to perform that will give you where the problem resides? I took the float out and it moves, but when the bike is turned on, there still is no registration on the fuel gauge when the float is moved up and down. Any ideas?
Old Apr 6, 2011 | 04:10 PM
Dr.Hess's Avatar
Dr.Hess
Measure the resistance of the sender. Move the lever through its arc and observe the resistance changing. If it's open or jumps around, the sender is bad.
Old Apr 6, 2011 | 04:42 PM
grbrown's Avatar
grbrown
Somewhere in your service manual it will say the resistance in ohms of your sender should be around 40 at one end and 250 at the other. Moving the float between those extremes it should vary between those. Essentially the gauge is an ohmeter, so there may be a test in the manual for that. Otherwise follow the wiring through the bike to check all connections are sound.
supermanotorious
Jan 26, 2019 08:00 PM
cowboybob56
Feb 2, 2018 10:05 AM
srhen
Electrical/Lighting/Alarm
Oct 19, 2017 09:40 PM
bigdaddy33
Sep 16, 2015 06:31 PM
BadBilly49
Apr 27, 2014 08:20 PM
