cruise control rocker switch
Old May 19, 2011 | 05:30 AM
RIDERV700's Avatar
RIDERV700
Stage IV
Unhappy cruise control rocker switch
my cruise control rocker switch broke. where would be a good place to look for this item for a 1994 ultra electra glide?
regards
Old May 19, 2011 | 05:55 AM
miacycles's Avatar
miacycles
Have your dealer do a search for it. If that fails get the part number and a Harley tour map, the map has the locations and phone numbers of all the dealers in it. Start close to you and expand your search outwards, as some dealers have stuff that doesn't show up on the dealer search. We've found lots of "discontinued parts" that way. Hope this helps.
Old May 19, 2011 | 07:52 AM
shifflettmc's Avatar
shifflettmc
http://partsfinder.onlinemicrofiche....e=13&A=26&B=41
You can order the Passing Lamp switch which has the same pinout from these guys for $25 each. The only difference is the lettering and the color of the light in the switch.
You could also call them and see if they stock the other switch also.
Old May 19, 2011 | 10:40 AM
RIDERV700's Avatar
RIDERV700
Stage IV
thank you both for the info. i will put it to use.
J McBri
Apr 24, 2020 06:32 PM
danzio
May 24, 2017 03:31 PM
outlawjess
Apr 7, 2012 09:56 PM
gregsworld
Sep 1, 2008 04:44 PM
BadPiggy
Dec 8, 2007 04:10 AM
