Recommendation on clutch
Old Jun 7, 2011 | 12:11 PM
Dr.Hess's Avatar
Dr.Hess
Graham, I just have the stock clutch pack and threw in one of the old ones. I think I put in an extra steel disk at the back of the pack. My clutch has 6 friction plates.
Old Jun 8, 2011 | 07:26 AM
renegado's Avatar
renegado
Originally Posted by grbrown
Lynn,
Can you describe in what way it was remarkable? Not trying to be funny, just curious to know what you like about it.
Matias,
The clutch in my bike is not only stock but the 1990 original, except for the addition of a stronger Barnett spring, to cope with my S&S 107. That gives 107TQ, so unless your motor is giving significantly more a stock clutch should be fine.
I haven't checked, but I would guess there is a minimum thickness below which the friction plates should be replaced? I told my builder, who installed the 107, don't replace things that are still serviceable. Don't 'fix' your clutch if it is still fine!
grbrown, is not that I need to fix the clutch, but here in Argentina we have to wait 2 weeks for every part. I want to replace my drive belt so I was thinking to make a complete overhaul of the primary while in there, so I can disassemble only once (bike has more than 50.000 miles with the original drivetrain).
Is not like that the stock doesn`t make a good job, but It`s seem cheaper a kit like these one www.jpcycles.com/product/630-802 than buying the OEM one. Maybe is a local dealer issue.
Doe`s anyone have experience with rivera clutch discs?
Best regards.
Old Jun 8, 2011 | 01:14 PM
Dr.Hess's Avatar
Dr.Hess
renegado,
I don't have any personal experience with Rivera clutches, but Rivera and Barnett used to both have very good reputations for clutchs and other products. However, I suggest you pull your existing clutch apart and inspect it before ordering. At 50K miles, your original clutch is probably just fine, unless you have been seriously abusing it for that 50K miles.
seamless07
Sep 15, 2013 09:27 AM
dgdamore
Nov 11, 2012 12:53 AM
fxstc1999
Jul 1, 2011 04:18 AM
justinmark79
Oct 3, 2010 06:07 PM
Treasure
Apr 28, 2008 08:53 PM
