"Ching cha ching" sound
Old May 25, 2011 | 08:37 PM
TurkeyRun's Avatar
TurkeyRun
Naw... that sound is "swipe.... beep beep beep beep.... rip... sign here please"
Old May 25, 2011 | 09:04 PM
omgtkk's Avatar
omgtkk
You wouldn't happen to have a gremlin bell on your bike, would ya?
Just askin'
Old May 25, 2011 | 09:10 PM
TurkeyRun's Avatar
TurkeyRun
Just askin'
Haha - nope. I have one on the Ultra and yea, it's a lot like that sound, just a tad louder.
Old May 25, 2011 | 09:43 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I have a sound like that on mine and I have decided it is either a buckle on one of my bags or my tools rattling around. I figure if it is something else I will find out what when it breaks.
Old May 26, 2011 | 08:11 AM
tc's Avatar
tc
Two things that I found after awhile that sounded much the same.
First, the small spring that held the ignition cover closed (FLSTC) fell off and the cover was tap tap tapping and driving me crazy.
Second, one of my fuel filler caps does not tighten fully and it vibrates and causes a similar sound.
Hope this helps,
Cheers,
TC.
Old May 28, 2011 | 08:29 PM
oppirs's Avatar
oppirs
Originally Posted by miacycles
Sometimes a loose muffler core can sound like that.
Great suggestion. My Samsons made that type of sound. Drilled a screw in to hold the core tight, good for 4 years now. I have hard bags so no ones the wiser.
Old May 29, 2011 | 05:34 AM
evofloyd's Avatar
evofloyd
Its easy to check out the primary chain. I'd put an auto adjuster on it {m6} and ya got your auto adjuster. If you didnt have the noise before you had the work done, good chance thats where its at.
Old May 29, 2011 | 03:14 PM
NutterFLH's Avatar
NutterFLH
Too many coins in your pocket may cause some noise.
Front brake pads do make some noise, too. Saddlebag latches, fender tip light, license plate, brake lines may touch other parts while vibrating, worn out muffler hangers, rear fender "bumper" etc.
I`m having a lot of noises on my bike. It drives me mad but can`t find where it comes from.
Old May 29, 2011 | 03:38 PM
frostyballs's Avatar
frostyballs
Stage III
I'd go with TC, my ingnition cover tings all the time and my left gas cap(the vented on) does same. Easy to check, just put a hand on it when you hear it next time to see if the noise stops.
Old May 29, 2011 | 04:49 PM
Fernf5's Avatar
Fernf5
+1 on this. My ignition cover on my '86 FLST makes a jingling noise as well.Mine still has the spring but unless I have the keys in the ignition when I'm riding the cover vibrates constantly at cruising speed. Sounds like it's not something obvious like this that you have. I just know that when you are moving down the road on a bike with wind, road noise etc it's hard to tell where a noise is coming from. Maybe you can get someone in a car to listen while you drive....
