Head Light Issues
Old Jun 27, 2011 | 08:08 AM
RodeoHard's Avatar
RodeoHard
Default Head Light Issues
Need a Little Help,
Bike: 1990 FXSTC
Issues: Had a short in the handle bars, so I rewired the the bars. While I was doing this I realized the head light was not wired properly so I attempted to follow the wiring diagrams but it will not work.
Note: I do remember where the yellow wire was connected, but I can't remember what the white wire was connected to. Any ideas?
Old Jun 27, 2011 | 09:01 AM
RidemyEVO's Avatar
RidemyEVO
I don't have wire diagram for a st but it does cover an fxr which is pretty much the same. Yellow is the low beam and blue is the high beam. Yellow from handle bar switch to headlite, on other side of switch you have the white wire which goes to hi beam and hi beam indicator, from handle bar switch you have the blue which will go to lights circuit breaker.
Old Jun 27, 2011 | 10:53 AM
RodeoHard's Avatar
RodeoHard
Default Head light Issues
Thanks for the info, I am trying to hook up the head light, do the yellow and white wires go directly to the high/low beam switch?
Old Jun 27, 2011 | 11:20 AM
RidemyEVO's Avatar
RidemyEVO
Yes Yellow and White go directly to the high/low beam switch and blue is the headlight power for either high or low.
Old Jun 27, 2011 | 12:19 PM
RodeoHard's Avatar
RodeoHard
Default Headlight Issues
Johnny on the Spot my Friend. Thank you for all your help.
Old Jun 27, 2011 | 02:14 PM
RidemyEVO's Avatar
RidemyEVO
Glad see you see the light Joe.
Old Jun 29, 2011 | 07:21 AM
RodeoHard's Avatar
RodeoHard
Thumbs up Head Light Issues
Turned out to be Operator Head space and Timing. The battery was dead, so I did not see the light until Plugged the bike into the charger.......
ojohn
Electrical/Lighting/Alarm
11
Oct 31, 2016 12:31 PM
HDV-GLIDE
Jun 14, 2013 05:35 PM
BIGBIRD123
Mar 14, 2013 02:59 PM
OLD 96
23
Aug 24, 2012 09:21 PM
dynagliding
Mar 5, 2012 04:26 AM
