fork fluid change question
Old Jul 12, 2011 | 11:51 AM
the blob's Avatar
the blob
Default fork fluid change question
i was just wonerding if jacking up the bike is needed to change the fork fluid on my fxstc?
my shop manuel says to jack up the bike but i dont own a jack.
Old Jul 12, 2011 | 12:05 PM
Jim Kraft's Avatar
Jim Kraft
Yes. The fork has to be extended when you take the caps off to replace the fork oil. You might try blocking it up on blocks. I have done that before I got a jack. How ever you do it, it does need to have the front wheel off the ground before you take the fork caps off.
Old Jul 12, 2011 | 08:00 PM
mustasz's Avatar
mustasz
I use simple car jack.You have to lift the f. wheel tiny bit,just enough to
make the tire spin. Then you can do the oil change.
Old Jul 13, 2011 | 09:48 AM
the blob's Avatar
the blob
thanks for the replys all. but im either gona buy a jack or borrow my dads!
Old Jul 13, 2011 | 11:16 AM
grbrown's Avatar
grbrown
All you need is a scissor jack under the frame, with the bike on the jiffy stand. A trolley jack would be the luxurious way of doing it! Use something between jack and frame to protect the paint. Loosen everything you want to unscrew before using the jack.
Old Jul 13, 2011 | 10:28 PM
the blob's Avatar
the blob
thanks man!! i just might give it a try!!
cggorman
Jun 27, 2016 12:28 PM
sven556
Apr 29, 2014 10:55 PM
DonN
Oct 10, 2011 08:45 AM
deepsea
Mar 8, 2011 09:32 PM
dFREDb
Feb 20, 2011 12:01 PM
