Intermittent Starting Problem
Old Aug 16, 2011 | 07:54 PM
dz1087's Avatar
dz1087
I had a loose nut on one of y wires under my gauge cluster. Took me a year of dealing with your problem, but as soon as I tightened that nut down, the bike starts great.
Old Aug 16, 2011 | 08:01 PM
Uncle G.'s Avatar
Uncle G.
Originally Posted by Tom84FXST
Install one of these and when your 25 year old wiring messes up, you can just push the button and start it manually.
http://www.jpcycles.com/product/380-528
That will solve any problem but a dead battery or, as I found out last year, burned out contacts in the solenoid. I decided that the starter owed me nothing after 17 years and 160,000 miles, so rather than rebuild the solenoid and have something else go in two months, I put in a new starter. I haven't had a problem since.
Old Aug 16, 2011 | 08:54 PM
RANGER73's Avatar
RANGER73
Check your connections at the ignition. Every thing you've said is connected to the same power source off the ignition.
Old Aug 16, 2011 | 09:21 PM
Cleetussnow's Avatar
Cleetussnow
Coincidentally, I removed that switch, the local indie guy told me this wasnt helping problem. I don't know if I want to put it back though. He said something about using one or the other, not both, and might be getting gummed up (seemed gummed up when I took it apart).
Tim Hoffman
Sep 3, 2018 02:30 PM
zkeisler
Jan 2, 2014 07:27 AM
shovelshort
Electrical/Lighting/Alarm
Aug 9, 2012 06:18 PM
kd4tsc
Sep 6, 2009 02:48 AM
Dagerazod
Jan 10, 2009 12:35 PM
