ring end gap.
Old Sep 15, 2011 | 10:09 AM
ultrastanley's Avatar
ultrastanley
Stage IV
Default ring end gap.
i m workin on a 94 evo. 80ci.had the pistons and cylinders checked and cleaned up,bores just needed a hone so still at stock size.question is whats a good end gap,harley manual and hastings specs are way different.
Old Sep 15, 2011 | 11:41 AM
miacycles's Avatar
miacycles
Go with the Hasting reccomendations and try to get them as tight as the instructions say, that way you will have less blow-by.Make sure that rou file the rings parralel and be sure to de-burr the ends that you filed. You will have to break the engine in a little easier until the rings seat and the gap opens up slightly. Hope this helps.
Old Sep 15, 2011 | 01:40 PM
ultrastanley
Stage IV
thanks for the reply.thats exactly what i was thinkin.harley calls for over twice the end gap than hastings does.talk about positive crankcase ventilation!thank god for the Airborne and the Marines,my father is an 86 year old Iwo Jima veteran.
Old Sep 15, 2011 | 10:38 PM
gsxrboy96's Avatar
gsxrboy96
great advice, rule of thumb is .004 per inch of bore, chad.
Old Sep 16, 2011 | 05:06 PM
SportsterBob's Avatar
SportsterBob
Hastings Rings come with instructions on where to postion each ring gap in the piston groove...
Hastings is the only way to go for piston rings...I phoned the Plant in MI and got a set of obsolete rings made and delivered within 3-days!!!! Lifetime Customer here!!!
dyna50
Engine Mechanical Topics
28
Sep 10, 2023 12:06 PM
RedJada
Classic
Apr 13, 2014 07:06 AM
UTAHKAT
Mar 5, 2014 10:24 AM
Harleycruiser
May 28, 2013 04:06 PM
CDN. RG
Exhaust System Topics
Nov 23, 2008 10:14 AM
