Installed twin cam guages
These are designed to bolt to an 1 1/8" axle spacer...shouldn't take but a little creative thinking to get it to bolt on.
http://www.debrix.com/Rear-Wheel-Spe...p/48638-m1.htm
Attachment 268197
If you're gonna go through all the work upgrading the front end and wish to use the electronic speedometer. Go ahead and go a little further to modify the transmission for the speedo sensor. It is extra work, but well worth the effort for the electronic speedo route....you'll be glad you did.
For someone interested in this conversion...don't just change the speedometer. Go ahead and upgrade the tachometer as well. The upgraded tachometer actually redlines at 6000 not that it really matters and it also looks more refined. The idiot lights are now built-in and offer the security light if a person adds security to their bike. Since I did the upgrade, I've already wired in factory security system. The check engine light was reloacted to the electronic speedometer.
Upgrade the speedometer and tachometer
Definately get the correct guage mount inside the fairing....I've since done that already.
Modify your existing transmission or replace all together...I had to go into my transmission, it was a good time to modify.
You don't have to get a used wiring harness from a 2000-2003 model. I only did because it was a really cheap find on Ebay. Plus, I was going into the unknown and I wanted everything. What I know now, you can custom make a wiring harness...but you do have to get the guage connectors and the speedo sensor.
I've since found another speedometer very close to the original mileage.
I am still happy with the end result.
You don't have to change out the tachometer, however keeping the original can create problems. You won't have problems with the wiring by using the original one. But, the guage bracket in the inner fairing might cause a problem. The original guage diameter is smaller than the 2000-2003 gauges. Much easier to use the newer tachometer and purchase the new style bracket...otherwise you'll have to modify the existing bracket. The new bracket is only like $5 from Harley...plus the tachometers are fairly inexpensve on Ebay. Simpler to just upgrade the tachometer too.
If you want a wiring harness....you'll need the main wiring harness from a 2000-2003 models. I see these on Ebay from time to time. You actually remove the speedo sensor plugin all the way to the gauge connectors. I think you only have to cut one wire from the harness to get the part you want. You can study the main wiring diagram and build your own...but if you can find it cheap enough, it already has the connectors. Plus, it has all the other connectors if you ever need them in the future.
The front fairing harness does not have the wiring for the gauges or speedo sensor. Harley wired the speedo sensor and the gauge wiring to the main wiring harness for some reason.
If you have access to a wiring diagram....you'll see how simple the speedo wiring actually is. It can be made rather easily. I think the section you need is attached to the main wiring harness only by one or two wires. I wouldn't have a clue what the connector part numbers would be.
I forgot to add you'll also need the rubber boot for the odometer reset button.
Let me know if you have any more questions or problems....
The 1996-1999 does not have the speedometer wiring. They are only wired to give light to the gauge since the speedometer is mechanical driven. There are not connectors under the seat for the speedometer.
The existing color coded wiring for the gauges are the same found 2000-2003 models. Basically, solder yellow to yellow, white to white...etc. Easy!!! Nothing is plug-in-play...must solder.
The speedo sensor wiring comes up from the transmission to under the seat. The gauge wiring travels from the inner fairing to under the fuel tank, to under the seat. There, the speedo sensor plugs in. The main wiring harness diagram shows the wiring...it's really quiet simple to figure out.
Try to locate a 2000-2003 wiring diagram and look for at the main wiring harness. 2004-up won't work as they are totally different. This will show exactly how the speedo sensor is wired in.
The link above shows a 2000 FLHTC main wiring harness. In the left corner of the diagram, you'll see the speedo sensor. As you can see, it's really straight forward.
If you custom make your harness, you'll need the three wires to the speedo sensor plus the connector. You'll also need the odometer reset button (comes with wire if purchased new). Lastly, the speedo connector and tach connector will be needed.
