Tour pak removal
Old Oct 25, 2011 | 10:15 PM
woody0404's Avatar
woody0404
Default Tour pak removal
I have a 95 Electra Glide Ultra Classic and just removed the tour pak tonight. I had to cut the wire bundle that controls the lights to the tour pak...any suggestions on how to make it quick disconnect? I also disconnected the CB under the tour pak mount and now have no radio...does the factory radio have any tie in to that CB module? Does anyone know of any quick disconnect for the tour pak that will fit a 95 or have any suggestions on what to do with that hideous factory mount plate? Any help is much appreciated...
Old Oct 25, 2011 | 10:22 PM
JohnG3's Avatar
JohnG3
Default Tour pack
Have you considered the trailer light plugs? flat rubber coated plugs with three covered wires and one uncovered ground wire. Depending on the number of wires you need to quick connect you may have to mark each pair.
Old Oct 26, 2011 | 05:18 AM
Tom84FXST's Avatar
Tom84FXST
http://www.google.com/search?q=deuts...w=1440&bih=686
Old Oct 26, 2011 | 06:36 AM
grbrown's Avatar
grbrown
Wink
That mounting plate is a thing of great beauty! Leave it as is and admire it at every opportunity.
I have twist-lock qd connectors on my bike, similar to this, the socket fixed into the front left corner of the floor, the male on the end of the harness. I don't have a radio so can't comment on that.
twitchcvma
2014-2024 Touring Models
Aug 5, 2014 09:12 PM
07JakeelwoodHD
Mar 16, 2012 05:06 PM
WoodyHD
Sep 16, 2010 03:52 PM
Craneman14
Mar 1, 2009 04:08 PM
