Difference in years
Old Nov 26, 2011 | 08:29 PM
theyammieguy's Avatar
theyammieguy
Default Difference in years
Not sure if this is where this question belongs but...
I have a 94 softail springer. Looking at an aftermarket speedo, I don't see many options. But when I look at 95 or 96 models, I see a speedo/tach combo from autometer.
Anyone know what the difference is between a 94 and 95?
Old Nov 26, 2011 | 09:19 PM
topfuel7's Avatar
topfuel7
Not sure about the difference in 94-95 but they went to the electronic speedo in 96. It has a totally different speedo and indicator lights.
Old Nov 27, 2011 | 11:05 AM
theyammieguy
Ok, so I wonder if there is a difference in transmissions or can I just use an electronic pick up and do away with the speedo cable?
Old Nov 27, 2011 | 11:08 AM
Tom84FXST's Avatar
Tom84FXST
You can get a rear wheel speed sensor, and use any speedometer for an 96 up....and you can lose the cable drive off the front wheel at the same time. https://www.google.com/search?q=++Re...w=1440&bih=686
Old Nov 27, 2011 | 11:10 AM
theyammieguy
I was thinking about that. Could I also use a tranny pick up?
Old Nov 27, 2011 | 11:17 AM
theyammieguy
Nevermind. It doesn't look like my tranny has the electronic speed sensor hole.
Old Nov 27, 2011 | 04:20 PM
PeteRock's Avatar
PeteRock
https://www.hdforums.com/forum/evo-c...am-guages.html
From what I've read here one can modify your tranny for installing a pickup. Good luck keep us posted with what you do.
Old Nov 27, 2011 | 04:28 PM
theyammieguy
Well, it looks like the pick up sensor hole is machined into the case of the transmission. So, I'll probably be buying a new/used case.
fredskie
Shovelhead
Jan 19, 2020 10:42 AM
thumper89
Jan 7, 2015 05:06 PM
1sandking1
EVO
18
Aug 9, 2012 10:03 AM
cookieonscooter
Jul 22, 2012 11:24 PM
jrbully
Apr 25, 2011 01:29 PM
