fork swap ultra
Old Dec 8, 2006 | 06:41 AM
seeltonc's Avatar
seeltonc
Stage II
Default fork swap ultra
is it possible to but front forks and brake calipers of a 2005 glide on to a 1990 glide.as i have been offered a set
Old Dec 8, 2006 | 01:13 PM
fxstcguy98's Avatar
fxstcguy98
Default RE: fork swap ultra
You would have to do the whole front end, axle size and fork diameters are different. I don't know if the triple tree will fit into the 90's head tube or not.
Old Dec 8, 2006 | 07:07 PM
89FLHT's Avatar
89FLHT
Should be able to slide the forks in to the existing triple trees with no problems. You'll need the brakes, brake lines and front wheel as well.
Old Dec 12, 2006 | 02:12 PM
98kingflh's Avatar
98kingflh
I know this doesn't help much, but I am putting a 06 front end on my 98. Not a whole lot of differences, but I have to swap all of the 06 gear to the old triples. I get the benefits of better brakes, larger axle, better parts. Keep researching and then make it happen. It is an easy swap...
Old Dec 12, 2006 | 02:29 PM
fxstcguy98's Avatar
fxstcguy98
I looked into this a little more, my mistake, the fork diameters are the same, it's the dyna line that got bigger forks I thought the baggers did too. You should be able to clamp the new forks right into the triple tree. Hopefully the newer brake cable is compatible with your master cylinder (or old cable with new caliper).
Jackpoticorn
Apr 2, 2015 08:56 PM
Sporty69
May 4, 2014 04:56 PM
neverdown
Jun 20, 2011 10:12 AM
bloodlust
Jul 9, 2010 04:00 PM
dynagliding
May 11, 2010 07:28 AM
