HELP-Headlight Wire to Cut During Starting '96 FLH
Old Feb 10, 2012 | 10:04 PM
Speed O's Avatar
Speed O
5th Gear
Originally Posted by Asuperglide
I'm looking to disconnect the mystery wire that keeps the headlight powered while engaging the starter switch. I have the headlight assembly out. Can anyone give me direction where this jumper wire is that can be disconnected? There's 3 wires to the headlight connector, yellow, black and white. From there in goes into a larger loom. Hoping I can find this without pulling the fairing completely off. TIA.
Hey whats up, had a thought; don't know if this would work but could you use an early model ignition switch like off a Shovelhead ? I have a 77' and first click is power on and second click turns on the lights. It might work. Ask around
Old Feb 10, 2012 | 10:16 PM
Speed O's Avatar
Speed O
5th Gear
Hey what's up, not sure if this would work but could you change your ignition switch over to a early model Shovelhead ignition switch ? I also have a 77' FLH. First click power is on and second click lights come on. It might work. ask around
Old Feb 12, 2012 | 09:45 PM
Asuperglide's Avatar
Asuperglide
Ok now I have something to work with. Thanks for all the replies and the extra effort to load the wiring diagram. I don't have a service manual for this bike yet. I had the batwing off over the weekend and couldn't figure it out. Easy off & back on so off again soon. Really appreciate the help!!
Old Feb 13, 2012 | 09:07 AM
rustybearing's Avatar
rustybearing
Here's what I did for my '03 springer. Headlight is out while cranking then comes on as soon as I release the start button. I put the relay under the gas tank on the frame. Might work for you. I got the relay at a stereo shop with the harness. $20
Attached Thumbnails HELP-Headlight Wire to Cut During Starting '96 FLH-relay-switch.jpg   HELP-Headlight Wire to Cut During Starting '96 FLH-starterrelay-1.jpg
Old Feb 14, 2012 | 05:04 PM
Asuperglide
Default Stumped...
Ok I have the batwing off and there isn't a jumper wire between the fuses that I can see. There isn't a solid green in the gang of 4 fuses. The wire color codes don't match but that would be just luck. Before pulling the faring I double check and started and the headlight is on during cranking.
Fuse block somewhere else???
Old Feb 14, 2012 | 08:53 PM
Asuperglide
Bump: Bike is a 1996 FLHTCI. Fuse block is on top of the radio. Second fuse in from righthand side (standing facing front of headlight) is "lights". Has 2 solid blue wires. Looks like 18 gauge and 1 red/black stripe 14 gauge. No solid green wires to any fuse. No loop jumper that I can see. Headlight stays on while cranking as noted.
Old Feb 15, 2012 | 03:31 PM
RidemyEVO's Avatar
RidemyEVO
Ok I got a chance to look in the manual and your schematic is definately different than mine is. I now understand why the others made the suggestions they did.
Looking at the schematic though I think if I really wanted to try isolating ignition startup from lights I might try wiring an inline on/off switch. I had one on my bike before I rewired my lights.
Old Feb 15, 2012 | 05:33 PM
95 Ultra's Avatar
95 Ultra
On my '82 Sportster years ago, it was the green wire to the ignition. Harley mechanic said just snip it in half. Worked like a charm. Not sure on the mid 90's FLH's. Gonna go look at mine.
Old Feb 15, 2012 | 08:05 PM
Asuperglide
RidemyEVO: Funny I was actually thinking about adding a on/off switch this afternoon to get it over with. I guess just a toggle switch on the low beam wire should do it? Agree?
Old Feb 16, 2012 | 07:03 AM
RidemyEVO's Avatar
RidemyEVO
I believe that would do it.
