Replacement crankcase
Old Mar 12, 2012 | 06:22 AM
ElectraDave's Avatar
ElectraDave
Default Replacement crankcase
I'm wondering about left side replacement cases...does H-D number these to existing frame VIN?
Old Mar 12, 2012 | 06:54 AM
miacycles's Avatar
miacycles
HD does complete cases on an exchange basis. Replacing one side entails a lot of machie work. You can buy replacement cases forw Ultima, which are stronger and can be already setup for big bore. Plus they now have cases and short blocks that are set up for TC cylinders and heads giving you 100 cubic inches for a reasonable prie as the market is flodded with TC take off parts. The best part is the cylinder bases use O-Rings to seal them. PM me for more info if you want. Hope this helps.
Old Mar 13, 2012 | 04:55 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by miacycles
. Plus they now have cases and short blocks that are set up for TC cylinders and heads giving you 100 cubic inches for a reasonable price
So if you build a "FATVO"...does it run hot like a full blooded twin cam
Old Mar 13, 2012 | 05:27 PM
grbrown's Avatar
grbrown
Talking
Only if you set it up to comply with current EPA emissions!
Roadflyer
Engine Mechanical Topics
Feb 20, 2025 05:14 PM
bbwolf63627
Exhaust System Topics
Apr 11, 2010 08:21 PM
tanglefootrgu
Jan 3, 2009 03:36 PM
markymark02
Jun 8, 2008 01:15 PM
thugged
Mar 23, 2007 05:26 PM
