Final drive belt starting to rip
Old Mar 30, 2012 | 09:11 AM
badcooky's Avatar
badcooky
REPLACE BELT AND THEN,true up the wheels.
Old Mar 31, 2012 | 01:09 AM
nibroc's Avatar
nibroc
atta boy--that's the correct prochedure!
Old Apr 2, 2012 | 06:46 PM
Rynb15's Avatar
Rynb15
well im pretty sure the wheel is straight. Measured from the back of the swingarm to the center of the axel. I adjusted so it is the same on both sides. It was a little off but not much. Belt is the same as before. So I guess i need a spacer to move the wheel over to the left. Or any suggestions? Thanks guys.
Old Apr 2, 2012 | 07:08 PM
Dr.Hess's Avatar
Dr.Hess
Back of the swing arm to center of the axle is not necessarily straight. Go through the alignment directions in the official HD Factory Shop Manual. It's a lot cheaper than a belt.
Old Apr 3, 2012 | 04:33 AM
grbrown's Avatar
grbrown
What Dr H says! The engine/trans/swingarm assembly are rubber mounted in the frame. That needs to be correctly aligned, before you can check wheel alignment. They are different things. If you are in any doubts about how to do it, find a local dealer or indy to check and correct it for you.
Old Apr 3, 2012 | 05:05 AM
Rynb15's Avatar
Rynb15
ok, will do. thanks again for all the info
Old Apr 9, 2012 | 11:20 AM
Rynb15's Avatar
Rynb15
so i pulled the wheel off and the spacers on each side are the same size. I though they are supposed to be different?
boise nightrain
Jul 2, 2018 07:43 AM
Spec36
Apr 2, 2018 07:11 PM
NoRegerts
Jun 4, 2013 10:36 AM
hddee
Feb 24, 2013 12:14 PM
uzuzap
Nov 7, 2009 08:18 PM
