Primary drain plug
Old Dec 28, 2006 | 12:18 PM
dert's Avatar
dert
Default Primary drain plug
92 Flstc..anyone heard of a primary drain plug "blowing out? Mine did and it took out the internal thread section...baffled ???
Old Dec 28, 2006 | 01:51 PM
brian1's Avatar
brian1
Default RE: Primary drain plug
Probably the threads were stripped by overtightening it and that's why it came out. Drill the hole out to the next size and re tap the threads. They were a tapered thread origionally (NPT) so it's easy for someone to overtighten it and strip it out. You can tap it and use a standard allen head bolt with a copper sealing washer on it.
Old Dec 28, 2006 | 01:54 PM
fmbeach's Avatar
fmbeach
What he said .....
Or if you have some threads left you can use a primary plug from S&S which is fully threaded and worked on mine.
Old Dec 28, 2006 | 03:40 PM
dert's Avatar
dert
Going with an allen..Ive laways hated the torx heads...Thanks.
Old Jan 2, 2007 | 11:06 AM
dert's Avatar
dert
Well,it was ok...after putting it up on a lift,it had fallen out.The book says to torque by specs,which I dont remember,but I put a new one in and ignored what the manual said,but used mucho teflon tape and screwed it all the way in....tight.just as our local dealer advised....we,ll see.
Old Jan 11, 2007 | 11:31 PM
Two As One's Avatar
Two As One
I use high temp lock tight.
Old Jan 12, 2007 | 03:01 PM
dert's Avatar
dert
If the hole could be dried good enough,I suppose loc tite would work but only the blue.
Dino M
Nov 7, 2010 06:05 PM
big_e78
Nov 29, 2009 07:48 AM
dagored11
Mar 23, 2009 11:14 PM
kraig205
Apr 30, 2008 04:05 PM
pitbull1
13
Aug 30, 2006 01:10 AM
