Its because the Softtail was always a rigid mounted motor and they didn't wanna redesign the frame.
The balanced motor is more complex.
Harley wanted to keep the traditional look of a rigid mounted engine for the Softail line, with the frame hugging the engine closely. A rubber mounted engine would spoil the look, so the engineers created the internally balanced engine.
Finally someone gets it, I also pull a plug a wire off when the old lady is on the bike with several waterhole stops, vodka & cranberry in her and it's a redneck honeymoon without a diamond ring. I'm all over this one
My question is why would they have a balanced engine and a rubber mounted engine? Why not have a rigid mounted balanced engine in the touring models? There got to be a reason other than tradition?
There is more to this than meets the eye! Traditional Harleys were solid mount and the current engines with balancer shafts are made to maintain that tradition. However they are heavier and the balancing system is a compromise, it also uses up power that could otherwise be used to propel the bike.
The other model ranges have rubber-mounted engines that isolate the rider and delicate bike stuff from both primary and secondary vibration. Primary is engine speed and gives the shaking that was commented on. Secondary are harmonics, ie higher frequencies, the sort of vibration that can give white finger and can destroy electronics.
This is actually a better engineering solution than the balancer engine and less restrictive on engine and bike performance. Using the balancer engine in a touring bike would add unnecessary weight and restrict performance. If it gave superior results I am sure the MoCo would have done it by now!
