sounds like a poor electrical connection. or low battery. Low voltage situations will allow a starter to turn but not fully engauge. double check your electrical work all connections, cold solders, etc.....
Have you tried to jump across the big terminal and the small terminal on the solenoid with the key on to see if it will crank? Tap the solenoid while doing this. It sounds like a solenoid problem.
Was it making any loud noises when starting prior to this? I'm thinking the starter clutch might be bad, but normally it makes a grinding noise when it fails to immediately hook up, prior to it failing altogether.
thats what the guys at the shop told me today, that it was the starter clutch. It was giving me problems every once in a while before, but after the long sit while doing the bars it went bad completly.
MY BIKE DOES SAME THING. I PUT PB BLASTER ON SHAFT. IT WAS VERY DIRTY IN THERE. SO FAR MY STARTER IS WORKING. THE FIRST TIME ITAPPEDTHE STARTER WITH HAMMER.
Sounds like the starter clutch to me. Had exact same problem a year ago and 1 day it did not want to catch at all. Change it now before you have to get pushed.
