Gear Lever.
Old May 5, 2012 | 03:02 PM
tc's Avatar
tc
Default Gear Lever.
My gear lever is very sloppy and I have been looking in various after market, CC, Zodiac etc, catalogues for bushes to fit.
I have been unable to find anything, so just wondering if anyone can help.
See pic.
Thanks
TC
Old May 5, 2012 | 03:34 PM
ILLEGAL REGAL's Avatar
ILLEGAL REGAL
How bout a new shift lever bracket? Chrome from drag is like $45
Old May 5, 2012 | 03:35 PM
BungoBill's Avatar
BungoBill
I have same problem which I put down to the design of the lever.
Because the the lever metal is "hard" the slot does not contract enough when you tighten the Allen screw. I know that silver foil or similar has been suggested in the past. I believe that a nut & bolt through the lever,instead of the Allen screw would tighten the lever much better although it wouldnt be as neat. Alternatively drilling through lever boss/flange & shaft, then a "pin" fitted could help. A heavy duty attachment to give you more leverage when tightening the Allen screw may also help. I notice in your pic. that the lever boss/flange is protruding slightly from the shaft end.
Old May 5, 2012 | 03:43 PM
tc's Avatar
tc
@ ILLEGAL REGAL. Nice Idea, but toget it here in Ireland, double price at least.
@ BungoBill. I know where you are coming from, but my sloppiness is not in the foot lever itself, but in the bush/shaft that the lever clamps to.
I was hoping that cheapish bushes might be available.
Old May 5, 2012 | 04:22 PM
ILLEGAL REGAL
Here's one on eBay for cheap...
http://*******/KD17LE
Old May 5, 2012 | 04:23 PM
ILLEGAL REGAL
Try this link
V-Factor Foot Shift Mount For Harley Fatboy OEM# 33630-90A
Old May 5, 2012 | 04:24 PM
ILLEGAL REGAL
Damn I can't get the link to work off my phone
Old May 5, 2012 | 04:27 PM
tc's Avatar
tc
Thanks for time and effort I.R, but cannot load either link!!!!!!!!!!!!!!!!!!!!
Old May 5, 2012 | 05:11 PM
miacycles's Avatar
miacycles
Check out some of the local bearing wharehouse for either a brass bushing or perhaps if tyou have enough material and can find a small enough needle bearing set up like for the cam bearing. Then drill it for a grease fitting if it isn't already. Hope this helps.
John
Old May 5, 2012 | 06:46 PM
ILLEGAL REGAL
http://www.ebay.com/itm/400263679528
got it that time..
