stock cv specs
Old May 10, 2012 | 10:20 PM
RidemyEVO's Avatar
RidemyEVO
Default stock cv specs
Anyone know the stock length of a cv carb spring and the hole that is sometimes drilled out larger in the slide?
Old May 10, 2012 | 10:38 PM
gsxrboy96's Avatar
gsxrboy96
I don't know how long the stock spring is, but the hole should only be about .090, a lot of times aftermarket springs are gold, where the factory one is silver. Chad
Old May 11, 2012 | 09:44 PM
ptcruiser's Avatar
ptcruiser
Not sure what the stock length is. I do have a spring from a dynojet kit which is silver and the length of it measures 5 inches. I may be mistaken but seams like when i did have the stock spring out it was a good 1 inch longer then the dynojet. Hope this helps
Old May 11, 2012 | 09:54 PM
RidemyEVO's Avatar
RidemyEVO
Thanks guys after doing somemore reading I'm finding that a stock spring holds the slide down longer which in turn keeps the needle down, so lighter spring means quicker response but more fuel.
Old May 12, 2012 | 07:58 AM
miacycles's Avatar
miacycles
Lighter spring doesn't mean better performance, if the slide comes up too soon you get a "sag" in the torque curve.
Old May 12, 2012 | 08:43 AM
Schex's Avatar
Schex
Found this a while back, stock spring on bottom.
Attached Thumbnails stock cv specs-springs.jpg-cv.jpg   stock cv specs-cvneedles.jpg
Old May 12, 2012 | 02:12 PM
RidemyEVO's Avatar
RidemyEVO
Thanks
god61021
Jul 29, 2013 05:35 PM
CC Rainman
Gear and Other Items For Sale
Aug 7, 2011 07:59 AM
terrapin88
EVO
Jul 25, 2010 08:01 AM
needadyna
Exhaust System Topics
Mar 9, 2006 02:38 PM
