vibration,
Old Jun 4, 2012 | 10:51 AM
gsxrboy96's Avatar
gsxrboy96
Originally Posted by vincentostapowich
Power train ,,not drivetrain.
Yes ! Lol been a long weekend
Old Jun 4, 2012 | 12:12 PM
miacycles's Avatar
miacycles
Check the clutch hub and everything else in the primary.
Old Jun 4, 2012 | 01:01 PM
gsxrboy96's Avatar
gsxrboy96
Anything in particular to look for ?
Old Jun 4, 2012 | 02:30 PM
miacycles's Avatar
miacycles
Bad or improperly adjusted chain, loose clutch hub, loose compensator nut, bad main gear bearing in tranny. There is something not right in there.
John
Old Jun 4, 2012 | 02:56 PM
gsxrboy96's Avatar
gsxrboy96
John
John. How do I check the main bearing in the trans ?
Old Jun 4, 2012 | 07:11 PM
miacycles's Avatar
miacycles
Pry gently up and down on the clutch basket, or if you have the basket off, do the same on the shaft. You can also drain the tranny when it's warm and look for metal.
John
Old Jun 4, 2012 | 07:28 PM
gsxrboy96's Avatar
gsxrboy96
It's a bad clutch hub bearing, thank u for all your advice ! Or atleast I think it is, the shaft is solid, but the hub has some play in it, enough play to where you can hear it when bolted to trans shaft ,
Hogntheroad
Jul 28, 2013 08:24 PM
Ugly Troll
May 15, 2012 04:41 PM
kschulz1960
May 11, 2011 12:14 PM
lou1
Nov 16, 2010 04:10 PM
hdparrothead60
Jun 24, 2008 11:45 AM
