New Carb Suggestions?
Old Jun 5, 2012 | 05:58 PM
Dyna7's Avatar
Dyna7
well i bought the manifold for 35 bucks (direct fit for the evo)
and i find out in two hours if i won the carb
should i put bigger jets in because of the motor build?
Old Jun 5, 2012 | 07:00 PM
miacycles's Avatar
miacycles
Just put the '88 sporty needle in it and turn the idle mixture screw out 2 turns to start. Read the plugs and go from there.
John
Old Jun 5, 2012 | 07:19 PM
Glider rider's Avatar
Glider rider
http://www.nightrider.com/
Old Jun 5, 2012 | 07:22 PM
Dyna7's Avatar
Dyna7
well i just won the carb for 80 bucks! so next week i will get everything to get it together...pretty excited over here
Old Jun 5, 2012 | 10:05 PM
Dyna7's Avatar
Dyna7
so for the intake,carb, and gaskets it costs me $150 shipping and all, i would say not bad, and ideas on an intake setup for the cv?
Old Jun 5, 2012 | 11:12 PM
Ultra89Rider's Avatar
Ultra89Rider
Well, the CV carburetor needs a support for the front. It just is held in place in the rear by a gasket. So unless you want to use the Harley Air Cleaner, get the carburetor support bracket (29116-83) used on the Keihin carburetor. It will provide the support needed without the big air box of the original.
I do have the original High flow Air Cleaner used on my EVO.
It has the base plate, filter, and uses the factory A/C Bell.
If you are interested, PM me.
Old Jun 6, 2012 | 12:11 AM
Dyna7's Avatar
Dyna7
ill be honest, i dont know how to pm haha
Old Jun 6, 2012 | 12:13 AM
Dyna7's Avatar
Dyna7
so i pulled the intake gaskets and there was oil inbetween the gasket and sitting in the port?
what would this be from?
Old Jun 6, 2012 | 01:12 AM
Ultra89Rider
Bad valve guide seals. You might need a head job.
Or at least the springs removed and seals replaced.
Old Jun 6, 2012 | 10:18 PM
1997bagger's Avatar
1997bagger
I don't know if a head job will fix the bike but the next time I find something wrong with the white bike, I'll see how the wife responds, havn't used that line yet.
