93 low rider wont start
Old Jun 23, 2012 | 07:16 PM
bikercouple's Avatar
bikercouple
The bike is on the lift now. I guess I need to lower the lift and unload it or can I lift the rear of the bike and turn the rear wheel ???
Bikercouple
Old Jun 23, 2012 | 07:23 PM
bikercouple
Question, the plug on top of the tranny just in front of the starter. It is about the size of a pencil eraser. What is it. I have a wire that looks like the end of a spark plug wire, a loop, Does it go there ???
Old Jun 23, 2012 | 08:19 PM
miacycles's Avatar
miacycles
Yes, it's the neutral light switch. Put the wire back on and the light should work.
John
Old Jun 23, 2012 | 09:45 PM
D1gger's Avatar
D1gger
The battery might be "new" but did you fully charge it first? Sounds like a low battery to me...
Old Jun 24, 2012 | 01:59 PM
bikercouple
I have 12.3 volts in battery.
Old Jun 24, 2012 | 02:00 PM
bikercouple
I put the wire back on the neutral switch and nothing !!! Grrrrrr
Old Jun 24, 2012 | 03:12 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Sounds like it is time to pull out the volt meter and start checking for voltage.
You can start at the small wire with a spade connector that connects in the middle/top right side of your starter. See if voltage is getting there (12 v). If no go back to the breaker switch then the starter relay.
Or you could start at your igniton switch and work the other way.
Something somewhere is not making contact.
Old Jun 24, 2012 | 03:38 PM
texashillcountry
Dirt don't hurt
Actually after thinking about it you could have a bad ignition switch.
You can check it by running a jumper across it and see what happens.
miacycles's Avatar
miacycles
Unlike on automobiles, the neutral switch on your Harley has nothing to do with the starter circuit. Check out the impulse wire to the starter and see if you get power to it when you push the starter button. If not check out the run/stop switch on the handlebars and your circuit working back from the impulse wire until you get power. You can see if it's the starter by running a "jumper" from the positive terminal of the battery to where the impulse wire goes on the starter. Just touch it to the terminal and the starter should turn over. Hope this helps.
John
Old Jun 24, 2012 | 04:24 PM
bikercouple
should the head light get power with the key on ???
