where do I start
Old Jul 19, 2012 | 01:22 AM
Bullys FLSTN's Avatar
Bullys FLSTN
Yes that 0 to ground is confussing cause as i found out the if you have any continuty to ground your stator is grounding to frame. Also you should have some resistance for the pin to pin test, like 0.1-0.5 ohms, you said it showed 0.
Old Jul 19, 2012 | 06:45 AM
1998ultra's Avatar
1998ultra
It's a greenlin meter...when I touch the probes I get 0000.0....probes open I get OL...pins with the red prob and case with the black I get 0000.0...I've never changed a stator looks like im gonna learn.
Old Jul 19, 2012 | 07:27 AM
miacycles's Avatar
miacycles
Open the primary and take a sniff.
John
Old Jul 25, 2012 | 07:22 PM
machinehed's Avatar
machinehed
Simple test ... set vom. to DC., probe pos. and neg. at battery . Run engine past 2000 rpm., read vom , should read approx. 14 - 15 volts if charging system is ok . If ok your battery is toast . Take battery to any automotive store and have them load test it " free test " so dont let them charge you for the test !
Old Aug 28, 2012 | 03:38 PM
kingofthecrate's Avatar
kingofthecrate
I have been having the same issue, bike died and I just replaced the battery and starter. I didnt even need to ohm out the stator. Its giving me 6.7 V @ 1000 rpm.. thats a pretty dead give away that my stator has gone on vacation indefinitely
taterbum
Electrical/Lighting/Alarm
May 9, 2015 10:57 AM
Kytann
Aug 15, 2013 06:21 PM
Astro
Oct 10, 2010 07:08 PM
ewhinger
Sep 19, 2010 06:51 PM
doakley2
Dec 19, 2006 10:13 AM
