s&s jetting
Then try 31 int as the S&S guy said.
When this is in order, start playing with the main. But before everything check for the air leaks, esp. manifold/head junction
Adjust your fuel/air mixture screw counter clockwise 1/8th of a turn.
Ride at least 25 miles and check plugs.
Repeat this until you see a slight tan color on the ceramic post in the middle of the plug.
The S&S manual is pretty good on jetting these things, and every bike is different. I've done our 2 bikes with S&S Super E's. Both carbs were bought specifically for the bike, per the label on the box. Neither was jetted anywhere near useable.
Get a collection of jets, bigger and smaller than what's in there now. Turn the accelerator pump off, change one thing at a time, ride it until it is warmed up, see how it goes, change it and try something else. Keep a log of what jets you had and where the idle mixture was set and how it ran/plug color. Check the spark plugs: ride it where you're testing (WFO, cruise, etc.), hit the kill button, coast to the side of the road, inspect the plugs. Go home and change something. Try again. Too fat runs like a pig or drowns out, too lean tends to pop out the carb.
My bike runs great, but I'm not real happy with the gas mileage. It's about average, I guess, based on what everyone else without a CV gets. Dr.L's bike is just not right for a Super E, and I never could get a carb to run right on there, and I tried the original butterfly, Screaming Eagle, S&S E. 883 with open drag pipes. A smaller CV would probably be good, and the knowledge out here on CV's has increased to where it would be possible without reinventing the wheel. I went with the Megasquirt EFI, though, and it runs fantastic now. Dr.L says it's like having an automatic transmission: just put it in a gear and go. No more dead spot, no more sputtering. My one of these day's project is to Megasquirt my bike but I'll need to upgrade the charging system first.
