Roughness & vibration on RH turns etc?
Old Aug 21, 2012 | 10:53 AM
lincolnmatthews's Avatar
lincolnmatthews
Thumbs up Roughness & vibration on RH turns etc?
Just completed a 1100 mile trip thru WA to Montana this last weekend with our 85 FLT what a pleasure still on this bike!!. Ran like a dream in the 100* F temps, avg. 44.5 MPG with the S & S!. Here's my quest for you seasoned owners. When I corner to the right at hwy speeds I get a roughness & slight vibration that you can actually feel on the hwy pegs, seat etc, then basically goes away when when you go back straight? Also on deceleration going down steep grades (on compression) I get this roughness, any thoughts??. I thought maybe the primary chain & sprockets. Has new tires & rear belt, chains been adjusted properly, all wheel bearings apparently are good, been repacked. Could be an engine that needs to be aligned properly?, so many things, one could just throw $$$ at it trying to find it. Appreciate any ideas or someone who still drives these old EVO'S who has experienced something like this. If I could fix this it would make almost perfect bike that much more enjoyable! Thanks for any ideas!
Old Aug 21, 2012 | 11:24 AM
miacycles's Avatar
miacycles
Engine alignment, maybe. But if the tires and wheel bearings are OK,I would look at motor mounts, cracked frame, cracked swing arm, or perhaps a bad swing arm bushing/bearing.
John
Old Aug 21, 2012 | 01:56 PM
Tampakingpin's Avatar
Tampakingpin
Not good news
Old Aug 21, 2012 | 02:00 PM
HarleyGyrene's Avatar
HarleyGyrene
I would still check the front wheel bearings and run out: just went through this same thing. New bearings, races, packed, etc. and they crapped out.
Old Aug 21, 2012 | 05:53 PM
machinehed's Avatar
machinehed
If you have noticed this " roughness " just after changing to new tires , i would suggest that the tires are just wearing in , especially if they are Dunlops.
If the bearings etc. are all ok try riding for a while to get used to the new tires OR take it back to the tire installer and describe your problem.
Old Aug 21, 2012 | 06:04 PM
lincolnmatthews
Thanks for the ideas, I've always felt that it was wheel brgs., but have had them replaced & repacked several times by different shops & they all say there fine. However none have ever checked the run out on the brgs. But I kind of gave up wheel brgs, due to the fact that it is also rough on deceleration going down steep grades at hwy speeds. And also the fact that its smooth on left turns, so odd?. Under acceleration it mostly goes away, kind of makes me think its the chain?. Hasn't been changed since 92 who knows?. As far as a cracked frame, I dobt it the bikes never been abused or hit, also swing arm bushings etc were just looked at everything ok when the belt was replaced a month ago. Sounds like I may have to find a very good indy that has had lots of experience with these old bikes, thanks again!
Old Aug 21, 2012 | 06:05 PM
Gunslingertom's Avatar
Gunslingertom
I have brand new Dunlop's on mine and notice literally nothing in the way of vibration/roughness.
I'd check what others have said and rear wheel alignment.
And if it's only doing it on right sweepers, well........... sounds like a swing arm bushing issue.
Old Aug 21, 2012 | 09:31 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I may be way off base here but have you checked your fork fluid?
Old Aug 22, 2012 | 10:25 AM
lincolnmatthews
Appreciate the ideas, had the forks rebuilt about 5yrs ago. They seem fine, smooth, anti-dive works etc. The indy that replaced the belt a month ago said the swing arm bushings & shaft were like new? still had the original lube on them & they came apart easy. (theres only about 50,000 miles on this bike). On hard right sweepers, it puts a hell of a strain on everything (2-up fully loaded) maybe the engine mnts, stabilizers flex enough to throw the engine off a little to get this roughness, who knows?. I guess now I can only ride it more & see how much worse it gets? Just hate to do any damage, before its found. I guess my long trips are over for this year anyway, will throw more $$$ at it next Spring. I've spent about 2 grand this past month on it getting it ready for the trip, (new windshield, pass. floor boards, tires & belt. Worth every penny spent, would kind of hate to have to get rid of the old gal now, looked at a new RG Ultra on the trip. They seem so Blah for 23 grand not even a pin stripe on the new ones. Just couldn't due it!. Sorry for the long post, just would like to get this one fixed. This has been going on for quite a long time, but is getting worse, but this is the 1st long trip that I've done for years,usually just short trips, so of course it seems worse now because of the hard driving for hours on end, thanks again!
Old Aug 22, 2012 | 12:08 PM
texashillcountry
Dirt don't hurt
Traildog just fixed a wobbling problem by tightening up his fender bolts.
