Brake sticking
Old Aug 22, 2012 | 06:11 PM
Chopperbob's Avatar
Chopperbob
Default Brake sticking
I pulled my front wheel and removed the bumper and reinstalled it and. Now my brakes seem to hang up sometimes I can pop the lever and they will release any ideas what I need to do I have lubed the slide pins and cleaned the mc out and added new fluid there but I did not bleed the system
Btw is 95 e glide with dual front disc
Old Aug 22, 2012 | 06:45 PM
machinehed's Avatar
machinehed
Have you pinched a brakehose while doing the front wheel work ?
Have seen older brake hoses that have been twisted or pinched during work procedures that will partely flake off an internal piece of rubber inside the hose and effectively produce a one way valve inside the hose allowing pres. to the caliper and stopping return pres. back.
Try to follow back what you did with the wheel work and look for any possble way that this procedure has caused your problem now.
Old Aug 22, 2012 | 07:07 PM
Chopperbob's Avatar
Chopperbob
Sorry it has stainless lines from good ridge never has had a problem and I have changed pads a bunch of times all I did was pull calipers remOve wheel and bumper I did plasti dip the lower legs and reinstalled wheels and calipers and it has been crazy ever since but it doesn't stick every time
Old Aug 22, 2012 | 07:10 PM
soft 02's Avatar
soft 02
If your caliper pistons were dirty and you removed the caliper and by doing so pushed the pistons in a little further that the normal operating range they can hang up due to the gunk being pushed into the bore. Just a thought...
Old Aug 22, 2012 | 07:12 PM
Owtlaw's Avatar
Owtlaw
My rear caliper was sticking a couple of months ago. I disassembled and cleaned the caliper. Hasn't happened again. Is just one caliper sticking, or both?
Old Aug 22, 2012 | 09:13 PM
monkeyboy22's Avatar
monkeyboy22
Easiest thing to do is clean the bore and piston. If that doesn't fix it, plan B.
Mark Adams
Jun 12, 2016 10:09 AM
wiseguyups
Mar 19, 2012 04:33 PM
40 Knuck
Aug 18, 2010 11:12 PM
davandsarah
Feb 6, 2009 09:52 PM
anubisss
Oct 3, 2007 04:10 PM
