Front wheel spins Hard after braided lines
Old Feb 5, 2009 | 08:25 AM
davandsarah's Avatar
davandsarah
Default Front wheel spins Hard after braided lines
Just finished installation of Magnum braided front brake lines, prior to this job the front wheel spun freely so i don't believe the rotors are warped,now it spins very hard. It was all put together properly per service manual including torque specs ( OK, maybe a little tighter than specs). Is this normal? I'm wondering if after a ride it will loosen up a bit? I bled the brakes good and have great pressure at the lever. Thanks for any insight. Dave
Old Feb 5, 2009 | 08:33 AM
sniper77's Avatar
sniper77
If all you did was replace the brake lines, it should free up when you drive it. Bleeding the lines surely tightened the pads against the rotors and a few miles and heat cycles should get things going.
Old Feb 5, 2009 | 09:12 AM
Certified Drunk's Avatar
Certified Drunk
You put too much fluid in the system!
Try resetting the calipers, Take the top the master cylinder off, take the caliper off and push the pistons back in the caliper. Watch out for the brake fluid spilling out of the master cylinder. Replace top, cycle brake lever a few times and recheck fluid level. Test ride it.
Old Feb 5, 2009 | 09:39 AM
davandsarah
I checked the caliper bolts and i had definitely over torqued them, loosened them up a little to the lower end of the torque setting and it helped alittle. This bike had the wheels switched to fatboy wheels and the previous owner had to have new spacers machined, he also had a spacers in between the fork and caliper on each side, with one sides being thicker than the other, he must have done it correctly because after 4000 miles the break wear on the pads seems very even, but I'm dealing with "customizations" now so this adds to the frustration, and I had the forks out to install profile springs, so I had allot apart as well.
Old Feb 5, 2009 | 09:40 AM
davandsarah
wish i could testride,its 7 degrees out in wisconsin,i'm a ways from riding.
Old Feb 5, 2009 | 10:02 PM
Berndude's Avatar
Berndude
If you removed the wheels even though they look pretty close there is a right spacer and a left spacer, if not put back properly you will have issues
Old Feb 6, 2009 | 09:18 AM
blueflht's Avatar
blueflht
i would recommend taking some brake fluid out before pushing in the pucks. then bleed the side farthest away first. depending on the yr bike some dot fluid is caustic to paint and chrome. so drain some first then add at the end to fill
Old Feb 6, 2009 | 11:33 AM
garyhendley's Avatar
garyhendley
what type of brake fluid does harley use??
Old Feb 6, 2009 | 11:41 AM
ranger56528's Avatar
ranger56528
DOT 4.....or.....DOT 5....should say on MC cover if ya have the original cover...or owners manual...is it the stock Brking system...
Old Feb 6, 2009 | 11:43 AM
ranger56528
my 06 Deluxe uses DOT 4.....
