I am having an issue with my rotor plug in the front of the primary case.
I know it is fairly common to have a leak from around the plug, but in my case, it seems like the leak is coming from INSIDE the plug.
No primary fluid leaks out from around the plug.
When I unplug it, INSIDE the male and female halves of the plug is leaked primary lube.
It is not enough lube to drip, but it IS enough to allowed the plug to become loose once or twice.
I don't see any way to RTV the leak without having to do it from the inside.
I've already ordered the spring to secure the plug in closed position.
So far, condition of the metal male and female plug halves inside the rubber plugs is good.
Any ideas on how to remedy this minor issue ? ... short of stator replace.
The previous owner of the bike said the stator had been replaced once before.
-CLC
What a pickle. There are some good sealants other than RTV but the degradation of the rubber coupled with the heat cycles whatever you find to seal it will eventually fail. End game is stator replacement or live with the leak.
I fixed mine with a zip tie as seen above, just enough preasure to pinch the rubber around the metal posts, still dry. This seems to happen as the rubber gets older and in my case, kind of soft or spongy. I think people might flex it too much when changing the filter, I'm real carefull now. Just make sure the regulator plug fits all the way on when you are done.
I was thinking along these lines earlier, but hadn't thought of using the ziptie, although I have a million of them and use them all the time.
Great info !
My leak is actually more of a light seep, and I bet this would make a difference.
Cool.
My first stator developed this problem. Fluid wicks up the wire and contacts inside the plug and gets in between the mating surfaces. My current stator has the entire lengths of the two wires overmolded with rubber in one piece with the plug to try to prevent this. It hasn't leaked on the inside yet, but started leaking around the outside after two weeks.
There is a thread here that describes all this..
Ds
That looks like my original stator. The plug protruded a long way out of the case just like that. My current (no pun intended) stator has a much shorter plug that tends to leak around the outside rather than the inside.
If I have to replace stator, I guess I will do what you did, but also black ultra rtv around the outside of the plug where it goes through case, AND ziptie around plug outside of case...
With all this AND one of those bolt on to the engine mount retainer clips, I should be OK... haha.
Mine did the same thing and drove me nuts. I ended up having so many problems with my primary with the clutch basket and leaks that I went with a dry BDL set up. No more leaks or problems.
I did put a bit of RTV sealant on the inside where the wires meet the plug and this helped to slow it down.
On my current (there's that pun again) stator, I tightened up the fit between the plug and the case by installing some o-rings in the molded "grooves" in the stator plug, then using some RTV. It held for about 2 weeks then started to seep when it was cold. It stops seeping when the motor is fully warmed up. This was an improvement over the original installation, so I left it for five years.
A week or so ago, I was doing an unrelated sealing job and using some "flowable" RTV (made to "wick" into cracks to seal windshield leaks). I had some left in the syringe, so, on a whim, I cleaned up the stator plug and case with electrical contact cleaner and laid a bead of flowable RTV around the junction of the plug and the case. I didn't expect anything to come of it, but the stator plug has been dry for 800 miles now.
