Looking for a NEW Engine Guard
Old Sep 29, 2012 | 05:11 PM
D1gger's Avatar
D1gger
Default Looking for a NEW Engine Guard
Just like the title says, I'm looking for a new engine guard/crash bar for Ruby. The original one is a little tweaked and scuffed up, so I want to replace it and I'm not having much luck.
Can anyone with access to parts lookup confirm a model year compatibility?
Anyone know where else I can look? I just want a stock chrome one, or possibly a beefier aftermarket chrome one, but it would have to be shaped the same as stock to fit the lower fairing supports. Please help!
Old Sep 29, 2012 | 07:13 PM
Mountainkowboy's Avatar
Mountainkowboy
You can go to a late model one, pre 08, like I did. You will need to drill 1 hole on the brake side, the newer bars mount lower on that side.
Old Sep 29, 2012 | 09:00 PM
D1gger's Avatar
D1gger
Drill it where? Into the frame or the bars? I don't see room for any additional holes to be drilled...
Old Sep 29, 2012 | 09:22 PM
Mountainkowboy
Where it mounts on the flat plate that the floorboards are mounted to. I can get a pic if you want.
Old Sep 29, 2012 | 09:28 PM
D1gger's Avatar
D1gger
That would help. I'm having difficulty envisioning it.
Old Sep 29, 2012 | 09:31 PM
Mountainkowboy
Give me 10 minutes
Old Sep 29, 2012 | 09:41 PM
Mountainkowboy
This is the right side mount, if you look you can see the origanal mounting hole for the factory bar. The newer bars mount a bit lower than the older bars. I had to drill a new hole to mount the bar as you can see. The bar below the mount is the front floorboard bar.
Old Sep 29, 2012 | 09:56 PM
D1gger's Avatar
D1gger
So that's a 97-08 engine guard on a 89-90 frame? And the one lower hole on the right side is the only modification needed for it to fit? This kept the upper section perfectly horizontal for mounting the lower fairing brackets for the shark nose?
Old Sep 29, 2012 | 10:24 PM
Mountainkowboy
Thats the bar thats on mine, it was from an 06. No issues with the fairing or the lowers on my 89.
Old Oct 8, 2012 | 02:33 PM
D1gger's Avatar
D1gger
Okay, I just installed a brand new aftermarket chrome crash bar. I drilled the hole just like MountainKowboy suggested(THANKS!, BTW) and it went on perfectly. Now with the extra hole drilled, not only can I still use the original 89-96 style, but the 97-08 as well. That's what I bought by the way, a 97-2008 Touring highway bar.
While I was at it, I replaced the seized and stripping out 3-piece clamps for my highway pegs with new Kuryakin Magnum quick clamps.
After I got the old one off, I was amazed to find out it was a little more tweaked than I thought. Both sides were bent, lower corners to the left side. I'm just glad the frame survived whatever caused the bar to bend.(I'm saying the frame survived because the new bar went right on and lined up perfectly without having to flex it into place at all).
Thanks for the advice, MountainKowboy! It worked like a dream.
