Clutch cable
Old Sep 29, 2012 | 08:29 PM
chris jacob's Avatar
chris jacob
Default Clutch cable
Hello all. I've been busy working on an unexpected home project while I striped my FXR and just got it back together. What is a good source for a new clutch cable? Mine is leaking a little and needs to be replaced. It sure is strange how many things that worked fine before I took everything apart now are having issues Anyway it looks great and runs better than it ever has
Old Sep 29, 2012 | 11:11 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
What exactly do you mean when you say your clutch cable is leaking?
Old Sep 29, 2012 | 11:12 PM
Mark_H's Avatar
Mark_H
Old Sep 29, 2012 | 11:17 PM
T_Dogg80's Avatar
T_Dogg80
Originally Posted by Mark_H
Me too...
Old Sep 30, 2012 | 10:24 AM
chris jacob
It's leaking where it connect into the transmission. Not a lot just a little drip
Old Sep 30, 2012 | 01:37 PM
HarleyReece's Avatar
HarleyReece
It's an o ring on my 95 fxstc that seals the threaded collar of the clutch cable to the trans. Might get way with replacing o ring.
Old Sep 30, 2012 | 02:13 PM
miacycles's Avatar
miacycles
+1 on the above, if it's leaking where the threaded end goes into the tranny then replace the o-ring first, you will need a gasket as the end cover has to come off. If it's leaking where the cable is pressed into the ferrule on the end, then you will need a new cable.
John
Old Sep 30, 2012 | 09:37 PM
chris jacob
Thanks I'll see if I can isolate it
Durham man
Aug 26, 2017 03:52 PM
machm1969
May 7, 2013 05:00 PM
schwinnanator
EVO
Jul 15, 2012 10:54 PM
skos
Oct 23, 2008 03:46 PM
Sally88
Sep 22, 2006 11:14 PM
