Torque question
Old Nov 5, 2012 | 07:41 PM
95 Ultra's Avatar
95 Ultra
Default Torque question
Just got my Cometic top end gasket kit via UPS with the metal MLS head gasket. The instructions that came with the kit say to torque the head bolts to 42 ft. lbs. The Harley shop manual recommends 16 ft. lbs plus 1/4 turn. Anyone know why the Cometic gasket has to be torqued so much more. I would hate to pull another stud out of the case.
Old Nov 5, 2012 | 07:59 PM
Jasper86's Avatar
Jasper86
cometic gaskets -> cometic instructions. same with James. Cant say whether or not that'll pull a stud (my bike has the newer style "shouldered" studs, which are apparently much less prone to bottoming out / pulling out)
16ft lb's + 1/4 turn is going to be (i'm guessing) at least 46lbs.
the James instructions:
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque.
Old Nov 5, 2012 | 08:16 PM
Tee&Vee's Avatar
Tee&Vee
+1
This is correct. And I think it is about 46 lbs when quarter turned.
Old Nov 5, 2012 | 08:57 PM
kbootch's Avatar
kbootch
I agree. Used Cometic on my last build - torque in sequence to their, Cometic, specs no extra 1/4 turn.
2009blackpearle
Engine Mechanical Topics
Jun 24, 2017 10:47 AM
jsbridgew
13
Jun 27, 2015 07:06 PM
gnaz
Exhaust System Topics
Oct 23, 2014 10:53 AM
HOG_0308
Jul 18, 2010 11:01 PM
KustimKool
Sep 19, 2007 05:24 PM
