bad petcock
Old Nov 8, 2012 | 04:17 PM
miacycles's Avatar
miacycles
Most pingels can be rebuilt. Most better bike shops have the kit. We've rebuilt dozens over the years.
John
Old Nov 8, 2012 | 04:32 PM
FXRSBilly58's Avatar
FXRSBilly58
John
Thanks. I saw the kit advertised, but it appeared to be for dealers, because it was only available with the parts to rebuild several petcocks. That kinda negated the whole reason for rebuilding one-that is to save money. Is it possible to buy a rebuild kit to rebuild just one? If not how does the cost of paying somebody, like you or your shop, to rebuild it compare to the cost of a buying a new one?
Old Nov 8, 2012 | 04:45 PM
miacycles's Avatar
miacycles
No the kits and the refills are for multiple petcocks. Cost is around half the price of a new one.
John
Old Nov 9, 2012 | 07:38 AM
FXRSBilly58
John
Thanks John. I predict a rebuild in my future.
Old Nov 9, 2012 | 02:37 PM
Uncle G.'s Avatar
Uncle G.
Originally Posted by swamperca
Don't use Teflon tape, it will get in the carb and screw things up, I know from past experience.
You could get fancy and do what Harley recommends in the service manual. Go to the plumbing supply store and get a tube of Loctite "Pipe Sealant With Teflon". Apply a thin coat to the threads and assemble. It won't shed pieces of tape into the fuel system and if you need to remove the petcock years from now, it wont be rusted to the tank.
Old Nov 11, 2012 | 10:36 PM
jjames's Avatar
jjames
Pingel was put on Saturday morning pretty painlessly. Longest part was syphoning gas. That thing operates effortlessly, looks a lot better/cleaner, and best part...actually turns the gas off when put in the off position. No more fuel on the floor between rides/stops. I'm going to pull the carb once the snow flies and check the needle, seat, and float but with a working petcock I was able to get out and ride all weekend.
Old Nov 12, 2012 | 07:12 AM
JohnnyC's Avatar
JohnnyC
I know I've been happy upgrading to one 2 weeks ago. I also find the little handle sticking out makes it easy to shut off while riding.
Do you also shut it off early or wait till you park?
It would seem that when I wait to shut it off when I park I still get a small overflow from the remaining gas in the line. But at least it doesn't keep seeping all the time it's parked, like before.
I didn't notice any performance increase. I've read here that some think a better flow improved performance ... I guess if the original petcock was slowing the flow it would make a difference.
Old Nov 12, 2012 | 10:18 AM
Doug S's Avatar
Doug S
I just drained my tanks using the stock petcock, took less than five min to drain about 1.5 gals. I don't think there is a street legal EVO out there that can burn that much fuel in such a short time so all this Hi-Flow nonsense is just that, nonsence.
I have a new Pingle on the way, wish I could find a new OEM stock one, my old one lasted 18 years and I'm not a fan of that little pingel lever or how easy it moves..
Ds
Old Nov 12, 2012 | 02:51 PM
jjames's Avatar
jjames
I wouldn't say the butt dyno noticed any better riding performance. It was never starved for fuel just never shut off. Also didn't want to pull the fuel line to drain from petcock because the problem was the petcock never shut off. I love the easy turn action, it's tucked away so I'm not accidentally hitting it. I have been turning it off when riding up to my driveway and then back to my barn just to keep from having any overflow once I park.
Old Nov 12, 2012 | 04:52 PM
JohnnyC's Avatar
JohnnyC
Shutting it off a block from home is getting to be a habit of mine. But I have to tell you that often out on the road I never see a leak. Like during a fill-up, run into a store or a restaurant stop when I forget to shut it off. But overnight in my garage with a petcock that wouldn't shut off, I've had to leave a pan under it and worry that the fumes may ignite when I start the car. Not now, but over the summer.
I can't believe I can't get the float valve to seal. I've done it all, and then some, to stop it . I'm thinking a carb upgrade would eliminate the trouble. But my current carb runs well, and is jetted for my cam.
Man, the things money could solve ... lol Or the little things a little money could solve ... I'm not greedy. lol
About a petcocks performance: I believe every petcock allows gas to pour out at a given speed, and none would starve the bike until you go nuts with a blower, or radical cam. But those with the diaphragm can restrict the flow when messed up.
