Road king 2001 Model
Old Nov 8, 2012 | 06:25 PM
999online's Avatar
999online
Stage I
Smile Road king 2001 Model
I have the opportunity to purchase a Harley Road King 1450cc version(not EVO) and limited version 57/150 12000mls since new, a friend has advised me to be careful as he had one similar that had cam shaft bearing problems and a was prevalant on Harley`s at the time, Harley did not recall them,which he thought they should, his was a 1999/2000 model V registaration in England, has anyone had similar problems or is this a one off.
Old Nov 8, 2012 | 06:43 PM
buggy's Avatar
buggy
99 was first year twin cam motor and the only so called issue was the cam chain tensioner shoes waering out. I had a 2000 with that motor and had no issues. I got 27k on motor before I changed mine only because I swapped cams. Now you have better options to fix that issue.
Old Nov 8, 2012 | 08:41 PM
vaham's Avatar
vaham
Yep, cam bearings were an issue, but not as much as the cam chain tensioners.. most of us used the cam bearing upgrade as a reason to put some decent cams in while changing cam chain tensioners...
Old Nov 9, 2012 | 08:21 AM
1984_FXRT's Avatar
1984_FXRT
The cam bearings/chain tensioner aren't a reason to stay away - the issue is easily and fairly inexpensively rectified w/an aftermarket gear-driven cam.
Old Nov 9, 2012 | 09:32 AM
grbrown's Avatar
grbrown
Wink
...or the factory retro-fit upgrade kit.
RedPanEd
Engine Mechanical Topics
13
Aug 14, 2015 10:41 AM
The Mayor
Exhaust System Topics
Jul 6, 2008 05:52 AM
Tuggin
Apr 21, 2008 07:27 PM
bruggy
106
Mar 20, 2008 07:58 AM
highwayking
May 15, 2006 03:55 AM
