CV carb problems
Sounds good right?
Sounds good right?
Easire to just lift it with your finger and see how much pressure it takes to shut it off and then look at the angle of the top edge of the float as soon as the gas stops flowing.
If its horizontal or over horizontal your float height is way out of whack.
Use 10.49 - 11.51 mm (0.413-0.453 in) use the larger figure on your case.
I can tell you this. I got my CV from a cat out in Cali. that rebuilds and makes them all new again, polished barrel and all. He does any carb for that matter if you send it to him, just sayin'.
The thing is, when I put my CV on and junked the $20 leaking Drag pitcock for the pingel, which I should got in the first place. Everything was fine until ONE day it just started leaking, kind of like overflow. But it wasn't, it was the plastic POS 90ş fuel inlet. It looked perfect, and I mean perfect no crack visible, except where it was molded. The molded seam was leaking and I called brother man up and told him. I told him I forgot about them things breaking when I flipped Harley parts at the Dealer. I forgot to tell him to replace that plastic one with a solid brass one. He shipped me one and that was that. No leaks
Maybe this story is a little too much information....
But I would definitely check the 90ş plastic junk inlet.
Cheers
