Ignition update 84' Evo?
Old Jan 6, 2013 | 08:44 AM
mturtle's Avatar
mturtle
6th Gear
Default Ignition update 84' Evo?
compufire,HI4,or Dyna 2000
What should I go with for easy of bike start up and performance?
Old Jan 6, 2013 | 08:58 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Got a compu fire in mine. Four years running. Set and forget it. Which ever one you get make sure that the coil ohms matches the ignition or you'll have problems later down the road.
Old Jan 6, 2013 | 09:32 AM
mturtle's Avatar
mturtle
6th Gear
thanks
Old Jan 6, 2013 | 07:17 PM
mkguitar's Avatar
mkguitar
the stock works pretty good, but if you gotta, gotta switch- I had great results from the H14E.
Mike
Old Jan 7, 2013 | 06:43 AM
JohnFlorida's Avatar
JohnFlorida
Ultima is 1/2 the price and the exact same ignition as a daytona twin tec
Old Jan 7, 2013 | 07:12 AM
113fatboy's Avatar
113fatboy
Your right about price But I think it's the dyna 2000i That it's the same as
Old Jan 7, 2013 | 09:20 AM
JohnFlorida
You are right my mistake
Old Jan 7, 2013 | 10:19 AM
1984_FXRT's Avatar
1984_FXRT
For a mild build that doesn't need a customized ignition curve, the Ultima seems to be workin' well in my '84 FXRT - single fire, selectable curves, and even w/coil it was less than half the price of my Daytona Twin Tec.
Old Jan 7, 2013 | 10:46 AM
JohnnyC's Avatar
JohnnyC
Crane Hi 4E on my ride. 3rd year, no troubles.
After-market upgraded ignition modules can be adjusted to provide an even better idle, hotter firing including starting, quicker rapid acceleration, higher RPM limit and faster top end.
You need to replace, or splice in a pigtail to fit the upgraded modules. Modules that mount in the motor have been greatly improved, some older one's including Cranes designed to be mounted in the motor broke down from the heat.
Old Jan 7, 2013 | 07:04 PM
mturtle's Avatar
mturtle
6th Gear
had to put compresion releases in.
still stuborn to start
