Second guessing clip install
Old Jan 13, 2013 | 07:08 AM
traildog's Avatar
traildog
Default Second guessing clip install
Well, since I don't have the bolts in yet, I'm gonna slide the jugs up and double check the wrist pin clips...you guys have me paranoid........
Old Jan 13, 2013 | 07:21 AM
95 Ultra's Avatar
95 Ultra
Lift up slowly on that jug so you don't go too far and have that bottom ring slip out. Are you using new clips?
Old Jan 13, 2013 | 07:34 AM
95 Ultra's Avatar
95 Ultra
You'll have that bad boy running by lunch time.
Old Jan 13, 2013 | 08:38 AM
traildog's Avatar
traildog
yep, new clips
Doubtful, I'm confused with all of the o rings and little seals that came with the gasket set. Trying to sort them out. Don't want to forget anything.
Old Jan 13, 2013 | 08:52 AM
traildog's Avatar
traildog
Since we are on the o ring gasket topic. Wanna play a game? Name that o ring/seal.
Winner gets CAKE!
Old Jan 13, 2013 | 08:53 AM
traildog's Avatar
traildog
No push tube seals......back to the Harley store......
Old Jan 13, 2013 | 09:56 AM
traildog's Avatar
traildog
And while I'm at it, does anyone know if I need to use o rings on the locating lugs sticking out of the top of the jugs? My manual calls for them, but with the cometic gaskets, I'm not sure they're needed.
Old Jan 13, 2013 | 10:24 AM
95 Ultra's Avatar
95 Ultra
Do you have the three piece metal cometic head gaskets?
Old Jan 13, 2013 | 10:30 AM
95 Ultra's Avatar
95 Ultra
If you have the three piece riveted head gaskets, then no, you don't use the o rings.
Old Jan 13, 2013 | 10:35 AM
traildog's Avatar
traildog
Thanks. Yes 3pc riveted.
