throtttle not snapping back
Old Jan 15, 2013 | 06:10 PM
traildog's Avatar
traildog
Default throtttle not snapping back
it feels kind of sticky in the grip. is it ok to put lube in there somewhere?
Old Jan 15, 2013 | 06:13 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I lube my throttle cables once a year.
I use a syringe to inject lube into the top of the cable and put a rag down on the tappet blocks to catch what leaks out.
Old Jan 15, 2013 | 06:15 PM
misinlink's Avatar
misinlink
Did you happen to adjust your right side controls recently?
Sometime people push the throttle tube too tight against the bar end and that will create drag.
You can also lube and make sure they are adjusted properly.
Old Jan 15, 2013 | 06:18 PM
texashillcountry
Dirt don't hurt
The problem is probably an adjustment issue.
95 Ultra's Avatar
95 Ultra
If you noticed it after installing your gas tank, it may be binding up underneath. Mine did. I had to lift the tank up and jiggle the cable around a little bit.
Old Jan 15, 2013 | 06:23 PM
Jackie Paper's Avatar
Jackie Paper
From your other post, sure your's is unhooked from motor.? Not sure what your setup is but I replaced my brake light switch a while back. When I took the clam shell apart, my twist grip slides off and mine had a lot of crud up in there. Since it appeared to be hard plastic turning on the chrome handlebar, I just cleaned it up. Fills great. Probably some silicon grease would do the job but I just think things like that attract dirt and other crude. Modern throttle and clutch cables slide in a nylon sleeve. If the get tight, they are worn out in a bend and need replaced. Just my opinion.
Old Jan 15, 2013 | 06:52 PM
traildog's Avatar
traildog
I'm running some lube down into the cables first Thanks.
Old Jan 15, 2013 | 07:10 PM
traildog's Avatar
traildog
dont know which one did it but, a combo of adjusting and lubing and she's snapping back! thanks fellers
Old Jan 15, 2013 | 07:13 PM
bluharley's Avatar
bluharley
I agree with Texas, sounds like adjustment. Mine gets a lot of resistance if my idler cable is too tight. Sometimes the cables slip out of the cable holds on the carb when I'm messing around, that will do it too. I just loosen everything up, and start over.
Old Jan 16, 2013 | 04:26 PM
Uncle G.'s Avatar
Uncle G.
You sure you didn't inadvertantly tighten the throttle lock screw while you were messing around?
