adjustable pushrods
Old Jan 20, 2013 | 12:27 PM
Pinetop's Avatar
Pinetop
Default adjustable pushrods
Finally finished installation of adjustable pushrods. It really takes two people to get it just right. The instructions I received did not give a requirement that the TDC be on the combustion cycle and you have to get it spot on for it to work. Anything less than exact will yield an unsatisfactory fit. I am lucky to not have been valves or worse.
Pinetop
Old Jan 20, 2013 | 03:50 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Since you say you received poor instructions, maybe you could tell us where you got them from?
You know...a post that might help someone.
Old Jan 20, 2013 | 03:56 PM
Doug S's Avatar
Doug S
Why does it take two people?
Thanks
Ds
Old Jan 20, 2013 | 03:58 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Deleted double post
Old Jan 20, 2013 | 05:16 PM
Jim Kraft's Avatar
Jim Kraft
It either takes two people or three hands which most people do not have. LOL. It takes three wrenches, one to hold the pushrod from turning, one to turn the adjusting screw, and one to tighten the lock nut. It can be done with two hands if you work it right though. Just easier with three.
Old Jan 20, 2013 | 08:01 PM
traildog's Avatar
traildog
When adjusted mine, I watched the rod to make sure it wasn't turning when I locked the 2 nuts together. I kinda turned them both the same amount at the same time if that makes sense.
Old Jan 20, 2013 | 08:49 PM
Doug S's Avatar
Doug S
OK, I get it, but I never though of a second person..
I'm a leftie, position the wrench holding the rod on the right, adjust the rod and then move the wrench for the adjuster so that it is relatively even with the one holding the rod, that way I can hold them both in my right hand. Then tighten the jam nut with my left.
You odd ball righties will have to switch things around..
Ds
Old Jan 20, 2013 | 09:35 PM
1997bagger's Avatar
1997bagger
Ds
Lefties have to stand on their heads to turn the jam nut in the right direction after reading adjusting instructions.
Old Jan 21, 2013 | 04:24 AM
Doug S's Avatar
Doug S
LOL..
I guess the righties can't read because they have to start on the left side of the page, you all should move to China where they start on the other side. They drive on the wrong side of the road over there anyways, and take your shirts with the pocket on the wrong side with ya....
hehehe...
Ds
Old Jan 21, 2013 | 06:58 AM
Pinetop's Avatar
Pinetop
Default instructions from Andrews
I had instructions from Andrews with the product.
The second person is to watch the piston to make sure you are at TDC on combustion cycle when the nut is secured.
Pintop
