Crankcase Breather
Old Jan 21, 2013 | 10:35 AM
traildog's Avatar
traildog
Default Crankcase Breather
Howdy!
I want to install one of these on Bertha, but she already has the Arlen BIG SUCKER installed and the mounting holes would need to be ground off in order for the bypass kit to work.
Does anyone know if there's another mounting plate that will work with the BIG SUCKER so I can use the breather bypass kit?
Attached Thumbnails Crankcase Breather-4000305_a.jpg   Crankcase Breather-402-081_a.jpg
Old Jan 21, 2013 | 02:54 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Here we go again. LOL
Old Jan 21, 2013 | 02:58 PM
bluharley's Avatar
bluharley
I thought the 6 speed gear set was a great idea!
BTW, I would have been purely a spectator on that, would be an educational trip for me!
Old Jan 21, 2013 | 02:59 PM
Jasper86's Avatar
Jasper86
Originally Posted by traildog
Howdy!
are you running a seperate carb support bracket? (you'll need one if not).
I went through this. its why i returned the BigSucker and bought a D&M cone filter. I didnt see the point of cutting up a ~ $150 A/C.
for reference
Old Jan 21, 2013 | 04:10 PM
traildog's Avatar
traildog
for reference
Bingo! that's the setup I want, but, I'd like to keep the pretty cover and air filter that came with the bike.
I'll look into the support bracket you mentioned.
Old Jan 21, 2013 | 04:24 PM
Jim Kraft's Avatar
Jim Kraft
I don't know who makes it but I have one on my bike that has a thin stamped back plate and bracket that bolts on with the vent pipe. I have a K&N air filter, so maybe they also make the back plate. The back plate does support the carb by the vent bolts.
Old Jan 21, 2013 | 04:38 PM
Jasper86's Avatar
Jasper86
yea, those are getting tough to find. its the factory HD carb A/C backing plate. (I was looking for one when I did my carb conversion, because I had the factory "stage 1" air cleaner already...bigger K&N filter, "dish" cover, and a rather nice chrome insert with the HD logo). I ended up running a borrowed S&S intake instead (was easily modified to plug the breather holes). I had planned on modifying the original EFI backplate, but seeing as I dont have access to a tig welder, that was also proving difficult
Old Jan 21, 2013 | 08:09 PM
1997bagger's Avatar
1997bagger
Good thing a sense of humor is required in the Evo section
Found a Screamin Eagle backing plate and support bracket that fits the banjo fitting crossover (Ebay), got it for $1.25 and had a SE air filter with it - win some and lose some, won that one, used the origional cover on the SE setup.
Old Jan 21, 2013 | 08:22 PM
traildog's Avatar
traildog
Found a Screamin Eagle backing plate and support bracket that fits the banjo fitting crossover (Ebay), got it for $1.25 and had a SE air filter with it - win some and lose some, won that one, used the origional cover on the SE setup. The SE filter stuff is flooded on Ebay
Just finished the 6 speed gear set.
Checking Ebay.......
Old Jan 21, 2013 | 08:34 PM
1997bagger's Avatar
1997bagger
A carbed Twinkie will work, have to use the fatter banjo bolts
http://www.ebay.com/itm/Harley-David...8c801e&vxp=mtr
http://www.ebay.com/itm/94-Harley-Da...82e778&vxp=mtr
http://www.ebay.com/itm/Harley-Stree...8aff20&vxp=mtr
I'm calling bull$hit on the gearset, we arn't as dumb as you think we are that we think we are......... heard this line in a movie somewhere.
