Misfire under load. 85 FLHTC
Old Jun 16, 2013 | 09:14 PM
  #31
Kickstand03303's Avatar
Kickstand03303
Was it the VOES? I am having the same problem. The VOES is the oldest part on my bike.
Old Jun 17, 2013 | 08:59 AM
  #32
JohnnyC's Avatar
JohnnyC
The VOES is a Vacuum Operated Electronic Switch. When you open the throttle the vacuum increases and this switch activates the timing advance curve in you ignition module. The timing curve changes from idle and low speed to the proper timing for acceleration and high rpms to keep the motor and spark correctly in time with each other. When activated it ground the signal to the module to complete the circuit. Test it by applying a suction to the vacuum line and test for continuity to close. No vacuum applied and it will register open, or not allow a signal to pass.
In the early days it was a set of weights in the distributor cap of a car, or in the case of our rides it was located in the nosecone, mounted on the points plate. Back in the day you'd change the weights to alter the timing for a hot rod with a cam.
Today everything is all electronic and this function is part of the ignition module's built in functions. They still do the same function, keeping the spark in sync with the motor speed.
Old Jun 17, 2013 | 09:22 AM
  #33
Dr.Hess's Avatar
Dr.Hess
Vacuum decreases when you open the throttle.
Old Jun 18, 2013 | 08:28 PM
  #34
JohnnyC's Avatar
JohnnyC
Doc, I've always trusted your experience.
I will look into that information again when I have a chance. (whole lot of stuff happening right now, we were hit with a high wind and hail storm yesterday, lots of devastation, and today was all day just to get my property partially cleaned up and I have a surgery tomorrow).
I truly feel when you open the throttle it creates High Vacuum. But I'll check my facts.
Old Jun 18, 2013 | 09:34 PM
  #35
Jackie Paper's Avatar
Jackie Paper
Remember back in the good old days of points and distributors with centrifugal weights and vacuum advance to control ignition timing, going down the road at a steady 55, the vacuum advance helped fuel milage but when you opened the throttle quickly to accelerate, the butterfly opened wide and the vacuum dropped off since then the carb was wide open to atmospheric pressure and the vacuum advance dropped off preventing ping. Same with the old vacuum driven wipers. Soon as you hit a hill, they would slow down or quit. Later models before they went electric use a vacuum pump built into the fuelpump. The highest vacuum is at idle with butterfly closed. In fact this reading is a good indicator of motor condition
Old Jun 14, 2014 | 01:01 PM
  #36
deniro78's Avatar
deniro78
Stage II
My question is did you figure out what was causing the problem? I have the same year and the same issue,changed everything,pickup,ignition box,coil,plugs and anything else,it cuts out like it loses spark then picks back up after backfiring thru the car,I'm thinking after talking to a Harley tech that there has to be a bad connection somewhere and he suggested checkinga single wire under the gauges,the gauges plug in with one big plug and one single wire,he thinks it may be the single wire,what was causing your problem?
Old Jun 14, 2014 | 02:40 PM
  #37
Dr.Hess's Avatar
Dr.Hess
My money is on the wire from the ignition pickup in the cone to the ignition module. I bet it is broken right under the cone, inside the insulation so that you'll never find it. Grab hold of the wires and pull on them. If one pulls like there is nothing inside the insulation, that's it. Do it when the motor is running and I bet it dies. Careful you don't burn yourself on the exhaust.
Old Jun 14, 2014 | 08:08 PM
  #38
Beemervet's Avatar
Beemervet
Another thread where the OP never comes back to report the solution......
Old Jul 18, 2014 | 04:20 PM
  #39
lynmark1's Avatar
lynmark1
3rd Gear
Default intermittent sputter
1985 FLHTCU with intermittent sputters too, top end just rebuilt, butterfly carb rebuilt, new wires and spark plugs. Did notice that there is a 52 and 175 jet on this beauty, swapped ignition module and coils with presumed good used ones. Just a cough low and high range and no real power loss. No vacuum leaks. Cautiously riding but after having to lay down a few dead presidents I hope I don't hurt it by continuing to run it.
Old Jul 18, 2014 | 05:59 PM
  #40
Tee&Vee's Avatar
Tee&Vee
Hello Lynmark,
Start a new thread to get some fresh perspective and an introduction. Welcome to the forum, again.
Tom
