engine restart?
Old Feb 23, 2013 | 08:19 PM
DBH6601's Avatar
DBH6601
Default engine restart?
Have had my '89 softail undergoing a major cosmetic rehab the las few months. Was running good and had full oil tank when I put it on the jack.
Changed oil tanks and when I pulled the original tank it was empty so all oil is currently in the sump. Now the question, should i put a little oil in the tank before the pending restart, or should i pull the plugs and crank it over until i have oil returning to the tank? Any other thoughts appreciated.
Old Feb 23, 2013 | 09:07 PM
Schex's Avatar
Schex
Put about 1/2 qt in the tank and pull the plugs,
crank it over till you get a return,
also route the vent hose to a container to catch the oil that might puke out when you start it.
Old Feb 24, 2013 | 12:23 AM
Spanners39's Avatar
Spanners39
It'll get messy whatever you do, have plenty of rags and degreaser to hand....
Old Feb 24, 2013 | 05:59 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Just for kicks you might want to pull the derby cover and make sure the oil didn't leak through to your primary.
That happened to a friend of mine a while back.
Old Mar 3, 2013 | 07:45 PM
DBH6601's Avatar
DBH6601
Ok guy's, I pulled the plugs and spun it over and watched for oil returning to the tank. Didn't take long and i had some coming back. Had some coming out of breather tube (hanging down under the frame). Figured I'd crank some more oil up in to the tank, It was still coming into the tank but a lot more was coming out of the breather tube. I kept at it until there was very little coming out the tube but I had a lot more oil under the bike in the catch pan than in the oil tank, I would guess 75-80% of the oil ended up in the catch pan. Question, is there more to this sumping problem than first appears, maybe vent gear broken, or what else? Any thoughts appreciated, Thanks
Old Mar 3, 2013 | 08:51 PM
miacycles's Avatar
miacycles
It's the check valve, not the vent gear.
John
totemsbeard
EVO
27
Nov 12, 2021 08:22 AM
adachris
Oil Archive (no new posts)
Sep 13, 2019 06:40 AM
rod9470
Shovelhead
May 8, 2013 09:28 AM
98glider
Ironhead
Sep 3, 2009 08:09 AM
meancana
Oct 4, 2007 09:08 PM
