Engine oil in primary
Old Mar 26, 2013 | 06:43 PM
Jim Kraft's Avatar
Jim Kraft
The oil leaking past the check valve would make the seal leak a whole lot worse. I think I would get the oil out of the crankcase and replace everything with proper amount of oil and see if it is still leaking into the primary. If it is still leaking into it then I would replace the seal. Lots of bikes will leak past the check valve when sitting for a few months without riding.
Old Mar 26, 2013 | 09:59 PM
RJM's Avatar
RJM
4th Gear
Ok test running sounds like a plan. I'm waiting on a new clutch, should be in this week. It will have to be a run in the shop though still 3 ft of snow here, supposed to warm up this weekend finally.
wlibert
Nov 1, 2013 01:09 PM
McBoney
Shovelhead
14
Oct 24, 2010 09:06 AM
brwdarr
EVO
23
Oct 15, 2009 12:03 AM
FastHoss
Ironhead
Oct 12, 2009 08:13 PM
shiny2003
Apr 15, 2008 02:23 AM
