Crankcase vent leak???
That oil vapor has to go somewhere. It is best to let it on out.
You could put a small cup under it when you park in your friends driveway.
Or perhaps a small drain pan.
I would think even a filter would fill up with oil over time and then drip anyway.
I made one out of pvc for the sporty and it's tywrapped to the frame under the bike out of sight.
You can make it vertical or horizontal.
All that's needed is a inlet, vent(don't need a filter like most show) and a drain,
a peice of pot srubber can be used for a baffle for the vent, but not absolutly needed.
Barbs can be used,
or drill the holes for a snugg fit and insert vent hoses about a 1/2",
if inserting hoses without barbs, cut them on an angle to make sure they don't butt against the inside and restict flow.
A petcock can be used for a drain or just a 1/8 pipe plug.
Painted it black to disappear under the bike.
here's a sketch of the one I made
some other examples here
http://www.google.com/search?q=diy+m...w=1344&bih=714
Barbs can be used,
