Broken axle adjuster
Old Jun 3, 2013 | 09:44 PM
E-Glidester 89's Avatar
E-Glidester 89
Default Broken axle adjuster
I have an 89 FLHS and my predicament is a broken axle adjuster,would of been easy to just remove the axle slide broke adjuster out but here's where it sucks>>someone welded extender adjuster "blocks" inside of the swing arm thus blocking the passage of removing the broken adjuster,not only welded bu a tight fit,carefully took a Dremel to it but can't get a full cut of weld,any ideas and also ideas of why someone would even install these and even further why weld them,thanks for any and all input.
Old Jun 4, 2013 | 12:04 AM
Bumpandrun's Avatar
Bumpandrun
Got a picture?
Old Jun 4, 2013 | 12:32 AM
Spanners39's Avatar
Spanners39
If its waht I think it is then you're pretty much screwed. Don't mess with the swingarm, welding and cutting, they don't hold up well to that sorta thing.
I would get a second hand swingarm if it was mine because I like to ride without worrying about stuff like swingarms falling apart.
A pic or a drawing would help though.
Old Jun 4, 2013 | 03:55 AM
grbrown's Avatar
grbrown
It is just possible the swingarm has cracked at some time and been welded to repair it. As Spanners suggests, chuck it and get a secondhand one.
Old Jun 4, 2013 | 07:35 AM
E-Glidester 89
Default Pics
https://www.hdforums.com/forum/attac...1&d=1370349281
Old Jun 4, 2013 | 07:41 AM
E-Glidester 89
It is just spot welded at the bottom,a really tight fit also,deff not going to damage swing arm,and failure is not an option,it will come out,lol,will fiddle more with it today,had to walk away from it last night>>>>STRESSED :# so hopefully will get some enlightenment today!
Old Jun 4, 2013 | 07:43 AM
E-Glidester 89
https://www.hdforums.com/forum/attac...1&d=1370349744
Old Jun 4, 2013 | 10:38 AM
grbrown's Avatar
grbrown
That part sticking out is not a stock Harley item, so someone has tinkered with things.
Old Jun 4, 2013 | 10:51 AM
E-Glidester 89
Yes sir,deff not an OEM,kind of confused on whether or not to replace back to OEM or roll with the changes.
Old Jun 4, 2013 | 10:59 AM
Dr.Hess's Avatar
Dr.Hess
Going back to stock would be my choice. Even if it meant a new swingarm. Whatever you do, this is my favorite Dremel bit:
http://www.amazon.com/Dremel-9903-Tu.../dp/B00004UDJL
Hard to find locally, but Amazon carries them. I have chewed up more 304 stainless with one of these than most people will ever see. It would get in there and chew out that weld.
