Gas tank question
Old Jun 12, 2013 | 03:29 PM
homiegfunk53's Avatar
homiegfunk53
Default Gas tank question
Is it possible to take a tank off an 01 heritage and put it on a 92 heritage. I realize 01 is efi, if it is possible, how can I make it work?
Old Jun 12, 2013 | 03:52 PM
Tommy Hager's Avatar
Tommy Hager
I was just reading on another thread about gas tanks swaps on a heritage. Might be worth a read. I cant remember if they talked about ur year or not.
https://www.hdforums.com/forum/softa...m-screwed.html
Old Jun 13, 2013 | 05:19 AM
grbrown's Avatar
grbrown
I have an '09 tank on my '90 bike, in other words with determination and imagination many things can be made to work, however it wasn't a simple bolt-on. After removing the EFI stuff you can fit a Pingel gas tap and adapter, which do fit straight on. As for the Heritage specific stuff I am not sure.
Old Jun 13, 2013 | 11:08 PM
cowboy 51's Avatar
cowboy 51
they should fit are you sure the 01 had efi? also aren't the 01 still split tanks?either way they should interchange , you'll just need to buy a fuel valve aka petcock for the 01 carb model ,I swap my 03 efi to carb just pull all the fuel pump & stuff out of the 01 tank ,maks room for more gas
Old Jun 15, 2013 | 09:57 PM
Uncle G.'s Avatar
Uncle G.
The Evo Softail has 2 piece split tanks. The twin-cam Softail has a 1 piece tank, so, no doubt the mounting is different.
Old Jun 16, 2013 | 04:18 PM
homiegfunk53
Yes I know.
Old Jun 16, 2013 | 04:57 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You will need to rewire all your indicator lights and get an electrical speedo.
Probably get a speedo off an 01 and wire it in.
Sounds like a lot of work to me but it would be very cool if you made it work!!
You will need a wiring diagram off an 01 and your 92 to figure this one out.
Old Jun 16, 2013 | 06:23 PM
homiegfunk53
Yea I think I'm just going to forget about the whole thing and do some body work and reprint my tank.
Old Jun 16, 2013 | 06:38 PM
texashillcountry
Dirt don't hurt
That is what I would do.
Old Jun 17, 2013 | 12:50 PM
homiegfunk53
Thanks anyways everyone
sbarnes489
Feb 16, 2018 09:35 AM
jett14
Dec 6, 2013 02:20 PM
DaSham58
Jul 29, 2013 08:32 AM
campdreamer47
Dec 12, 2008 10:03 PM
Domestic Violence
May 12, 2008 11:07 PM
