Broken Shift Spring
Old Apr 25, 2014 | 07:47 PM
Beemervet's Avatar
Beemervet
First make sure you don't have stripped splines on the shifter.
Old Jun 28, 2014 | 08:24 PM
Tony_N's Avatar
Tony_N
Well out for a ride today with a couple friends and I think the shifter return spring broke. It wouldn't return to center and I had to do it manually to be able to upshift and down shift. Also a lot if play in the shifter that wasn't there before.
Old Jul 18, 2014 | 09:55 PM
Tony_N's Avatar
Tony_N
Pulling the primary, and transmision was more than I was comfortable getting into, so I had Pro Twin Performance take care of the repair. While they were in there they went with a Baker Drivetrain Anti-Overshift Ratchet Shift Pawl Assembly which means smoother shifts and no more broken shifter shaft springs. Also went with the Baker High Torque Bearing kit. Luckily no damage to the gear set.
Sucks that just 5 months ago I had to replace the inner primary housing along with all the seals...only to have all that pulled again to get into the transmission for the shifter spring...but it's back on the road now.
Old Jul 18, 2014 | 11:31 PM
92Fatty's Avatar
92Fatty
Glad your back on the road Tony. Nice looking Heritage btw.
Old Jul 19, 2014 | 11:43 AM
Tony_N's Avatar
Tony_N
Thanks..I appreciate it. Nice Fatboy there too!
doc308
Shovelhead
Jun 6, 2019 08:44 AM
pd76
EVO
Sep 25, 2011 12:47 PM
Solomon
Feb 2, 2011 09:01 AM
JSkinner3u
Sep 7, 2010 08:00 AM
jammer1
Oct 30, 2006 03:50 PM
