Remember I told you about a hose with a plug in it, hanging under the bike? THAT'S where the oil drains from the tank!
You told me the hose was 1/4"
The drain hose should be 1/2"
If you look on the right side of the frame just behind the transmission you should see a small clip. That clip should hold the hose. It shouldn't be hanging free under the bike.
As for changing the fluids I do that with every vehicle I buy just to make sure everything is ok.
