Evo carb
Old Aug 9, 2013 | 04:11 AM
citytrucker26's Avatar
citytrucker26
Another tip is replace the jets with brand new ones... I saw a jet wear down on an S&S carb to where if you took a needle out of a cv carb it was out 1/4 on the new one, and 1/2 on the used one.. Improper metering. they DO wear out! Look up jetting on google for whatever carb you are running. Or just go buy a few different sizes close to what you have. The main jet is the one that gets the most action and wears the quickest from what I have seen. Trucker Gary
Old Aug 9, 2013 | 06:29 AM
Kushman's Avatar
Kushman
Follow the instructions miacycle gave you carefully and as mentioned take a good look at the float fuel valve or get the rebuild kit and replace ii to be sure.
Check out CV Preformance http://www.cv-performance.com/carburetor-parts/
they have a lot of goodies for the cv, if you change your needle to the N65 you will have a lot easier time tuning and won't have to mess with clips.
The cv carb is pretty easy to work on and understand, take you time and it s a fun and easy job rebuilding them.
Cheers
Old Aug 9, 2013 | 12:02 PM
Hackd's Avatar
Hackd
Originally Posted by citytrucker26
when installing any of the intake gaskets, use dish soap and water to make sure they seal real good. Very important! or spit works in a pinch too..
I use Windex to lube them. Works good. Also good for removing rings from fingers that have swollen.
Old Aug 9, 2013 | 07:41 PM
cowboy 51's Avatar
cowboy 51
yes go to C V performance Ken & them over there know there stuff & he makes all his parts here in the US not like Harley from japan
Old Aug 10, 2013 | 05:38 PM
95 Ultra's Avatar
95 Ultra
One other thing to check, with the bowl off, look at the two "ears" that hold the float pin in place, and make sure one isn't cracked, allowing the float to bounce around when it's running.
Old Aug 12, 2013 | 12:52 PM
GPz11's Avatar
GPz11
Clogged pilot jet, clean it out or replace it.
My FLHTC had the same issue after it was parked for 5 years. Would run fine with the choke on but die otherwise.
Old Aug 22, 2013 | 05:59 PM
ponch3640's Avatar
ponch3640
Update....carb rebuilt and cleaned, fluids changed, plugs changed, bike is running good now. Float bowl needs adjustment as I still have some fuel draining after shut off
Old Aug 22, 2013 | 06:11 PM
Slammed-N-Senseless's Avatar
Slammed-N-Senseless
I don't think this was mentioned, but you may want to replace all of your fuel lines. They can degrade in time and little particles will clog your jets, making it a headache to diagnose over and over. For no more than new fuel lines cost, it just makes sense. Also, if your still having problems with fuel overflow, your float may not be positioned correctly, you can bend the tab on the float to raise or lower the fuel level in the bowl.
Old Aug 22, 2013 | 06:18 PM
bluharley's Avatar
bluharley
I bought a rebuild kit for my cv a while back. After installing the new float needle, fuel over flowed. I fought with that problem for two days. I finally just put the old needle back in, ridges on the rubber and all. Problem solved. I have no idea why that new needle would not work. When I laid it side by side with the old one, there were a few minor differences, but nothing to prevent it from working. It had me stumped...still does. A guy gave me a cv he had around from an old bike. That carb had the same problem, I could not get it to stop over flowing. It's a puzzle I never solved.
Old Aug 22, 2013 | 06:22 PM
ponch3640's Avatar
ponch3640
Sorry forgot that part all fuel lines were changed. Gonna mess with the float this upcoming week.
