91 Ultra. Interchangeable Frames?
Old Aug 19, 2013 | 11:15 AM
BungoBill's Avatar
BungoBill
Default 91 Ultra. Interchangeable Frames?
Help! what year EVO Frames are interchangeable with my 91 Ultra FLHTC.?
Old Aug 19, 2013 | 12:03 PM
grbrown's Avatar
grbrown
Looks as if a frame from 89-92 will fit, part # 47900-89A. Hopefully an expert can confirm!
Old Aug 19, 2013 | 12:22 PM
grbrown's Avatar
grbrown
Bungo, there are four at present on US Ebay in that age range, if that helps.
Old Aug 19, 2013 | 04:56 PM
BungoBill's Avatar
BungoBill
Graham,I have looked at most H.D FLHT 91,92 & 94 frames on US ebay. One breaker/dismantler contacted said that 89-98 EVO/FLHT Frames are interchangeable. Not too sure if that info is correct. Bungo.
Old Aug 19, 2013 | 05:04 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Have you decided to get a whole frame?
Old Aug 20, 2013 | 12:03 AM
Ken Oaff's Avatar
Ken Oaff
around 95/96 they lowered the seat height and inch so that info is not correct
Old Aug 20, 2013 | 03:50 AM
grbrown's Avatar
grbrown
Bungo, various things happened mid-life with our Evos. One is they went to a longer swingarm, although the earlier shorter one will fit (I swapped my early short one for a late TC long one). In addition the seat mounting changed, however one of the most important changes is doing away with the oil bag, when engine oil was moved to under the trans. It would be simplest to get one from the earlier years IMHO, just to minimise any snags that may arise.
Old Aug 21, 2013 | 11:30 PM
Ultra89Rider's Avatar
Ultra89Rider
I am talking about the frame Only. You can use a frame from 1979 to 1992. All parts from your frame will bolt to the frame without any modifications.
The "breaker/dismantler" is wrong about fitting up to the 1998 models. True, they all had the EVO motor. But the first major change to the frame happened in the 1993 model year. Beginning in 1993, the oil tank was moved under the transmission. The rear brake master cylinder was moved about 3 inches forward, but still inside the frame. This change was made to make room for the oil tank and lines from the oil pump. if you get a frame, don't get one from 1993 to 1998. Your 1991 is different.
I speak from experience and manuals. grbrown will back me on my knowledge.
Old Aug 22, 2013 | 06:48 AM
texashillcountry
Dirt don't hurt
Granted I am not Graham but I have never seen the Klingon be wrong!
Old Aug 22, 2013 | 06:49 AM
grbrown's Avatar
grbrown
Thumbs up
Nor have I - he's out of this World! Ultra to the rescue again!
